02-10-2014, 03:20 AM | #1 |
Rock Stacker Join Date: Mar 2011 Location: coos bay, Oregon
| RC4WD CMS on short wheel base...
I've searched and have been reading different posts on rc4wd's new cms kit. So far, I've discovered that it is intended solely for the honcho wheel base rigs of 12.3 inches.. I have the original kit form of the scx10 with the 11.4 inch wb.. What has got me somewhat puzzled is can the kit be used with the shorter wb just by building a new top link that is 15 mm shorter, or is there more to it? Any help would be awesome!
02-10-2014, 06:41 AM | #2 |
Pebble Pounder Join Date: Sep 2011 Location: Medford
| Re: RC4WD CMS on short wheel base...
I put mine on a 12.3 WB and some of the brackets and mounts go in the c channel of the frame rail and shock hoops. If I'm correct the 11.3 vehicles have the hoops brought in closer to the center and the frame rails are shaped a bit differently so it might cause fitment issues. What I have going on with my scx10 is stock honcho front links and shorter rear links in the back so I'm at about a 12" WB. Here is a link to my install of the cms kit. It starts on post #32 Matts scx10 action! I hope that helps, the kit it awesome by the way! |
02-10-2014, 10:13 AM | #3 | ||
| Re: RC4WD CMS on short wheel base... Quote:
02-10-2014, 12:37 PM | #4 |
Ok, thanks for the help guys! I guess I'll pick one up and give it a shot. I'll be sure to post up what I finally end up having to do! Well, went a ahead and picked up the kit. The only thing that needed to be done was to build a new upper link. I used the rod ends that came with the kit and cut my 3mm allthread to 91mm and the aluminum tubing to 63mm. Put it all together and it works like a dream! Absolutely NO bump steer and NO side shifting of the axle during suspension cycle. Last edited by THX_138; 01-29-2016 at 09:26 AM. |
02-17-2014, 04:42 AM | #5 |
Newbie Join Date: Jan 2014 Location: DFW
Looks nice, have you tried crawling with it yet? Is it any different?
02-17-2014, 02:39 PM | #6 | |
I was quite impressed with how smooth it went together. Not to mention, they leave you with quite a bit of extra hardware and a couple extra rod ends! Last edited by THX_138; 01-29-2016 at 09:28 AM. | |
RC4WD CMS on short wheel base... - Similar Threads | ||||
SCX10 Short Wheel Base. The Summit VCX16 | OhioGuy82 | Axial SCX-10 | 3 | 02-19-2014 07:23 PM |
Short wheel base drivetrain solutions. | ranger4xlt | Axial SCX-10 | 4 | 11-28-2012 08:46 AM |
xr 10 with 2009 Jeep rubicon short wheel base body | dusty sweep | 2.2 Scale Rigs | 3 | 11-23-2011 11:12 PM |
Hows this for short wheel base? | murdock | Chit Chat | 0 | 06-11-2011 12:08 PM |
