02-11-2014, 02:15 PM | #1 |
RCC Addict Join Date: Jun 2013 Location: Port Saint Lucie, Florida
| How to bullet Proof an SCX10 (Based off Harley's Wraith thread)
Since it's been asked and isn't really a straight up thread to answer the questions, i figured i'd take it on myself to borrow Harley's "Guide to a bulletproof Wraith" and apply it to the SCX10 Sorry Harley if i step on toes, i don't mean to!! Upgrades (assuming RTR) in order of importance. Stage 1: Knuckles Chubs Lower links Upper links Steering links Aluminum Hexes Stage 2: Tires Wheels Lockouts Transmission gears Driveshafts Lockers or spool Beef Tubes All bearings Stage 3: Shocks Transmission Top shaft and slipper Axle housings Axle Gears Metal Shock towers Stage 4: Metal Trans Housing Heavy duty outputs HD rear axle shafts Last edited by Richterat83; 02-13-2014 at 08:09 AM. |
02-11-2014, 02:15 PM | #2 |
| Re: How to bullet Proof an SCX10 (Based off Harley's Wraith thread)
Axles: Front Axle Housings: Vanquish Products - SCX10 Axle Housing C-hubs: Vanquish Products - Stage 1 Kit Knuckles: Vanquish Products - Stage 1 Kit Bearings: FastEddy Axle Shafts: Axial Universals - Axial Wraith Universal Set Lockers: Locked Up RC Spool Gears: Axial HD Axial HEAVY DUTY BEVEL GEAR SET Servo Plate: No need to change Servo Posts: GH- TowerHobbies.com | 04056 Golden Horizons Aluminum Servo Mount Black Axial AX10 Tie Rod: R2J SST links Drag Link: R2J SST links Aluminum Hexes Rear Axle Housings: Vanquish Products - SCX10 Axle Housing Lockouts: Vanquish Products - Stage 1 Kit Bearings: FastEddy Axle Shafts: Coming soon Lockers: Locked Up RC Spool Gears: Axial Underdrive Axial HEAVY DUTY BEVEL GEAR SET 43T/13T Aluminum Hexes Last edited by Richterat83; 02-11-2014 at 02:27 PM. |
02-11-2014, 02:27 PM | #3 |
Suspension: Lower links: R2J SST Links Upper links: R2J SST Links Shocks: Proline Powerstroke (Verify? I"m on Traxxas Big Bores) Chassis side shock ball: Dlux - Big Bore Shock Ends Sway bar: Axial Front - Axial Wraith™ Sway Bar Set Front (Soft, Medium, Firm) Rear - Axial Wraith™ Sway Bar Set Rear (Soft, Medium, Firm) Can someone vouch on swaybars for the SCX10? I havn't even searched it yet Transmission & Driveline Replacing Wraith style case with AX10 style case and extended outputs Case: Vanquish Products - VP Axial AX-10 Alum Trans Housing Top Shaft: SuperShafty #SS-112A - AXAIL BOMB PROOF MODS Spur/slipper: Robinson 32p 56t Gen 3 Steel Slipper - Robinson Racing HP Slipper Unit 56T Gen 3 Slash Idler gear: Robinson Racing - Robinson Racing Hardened Steel Idler Gear Wraith Final Gear: Robinson Racing - Robinson Racing Hardened Steel Bottom Diff Gear Wraith Outputs: SuperShafty #SS-111 - Needs to be modified to 6mm AXAIL BOMB PROOF MODS Bearings: Teamfasteddy.com Motor plate: BWD - FOFF Motor Plate Driveshafts: MIP - MIP C-Drive Spline Set for Axial AX10 Scorpion (2) Driveshaft hub: MIP - TowerHobbies.com | 08137 MIP Drive Hub 6mm E-Revo/Maxx Last edited by Richterat83; 02-11-2014 at 02:30 PM. |
02-11-2014, 02:30 PM | #4 |
Will finish editing later
02-11-2014, 02:51 PM | #5 |
Quarry Creeper Join Date: Mar 2006 Location: Pewee Valley, Kentucky
Subscribed!!!
02-11-2014, 03:00 PM | #6 |
IMHO, Stage 1 should be drivetrain: Robinson Racing Solid Outdrive Gear: Robinson Racing Outdrive Diff Lock Gear AX10/SCX10 Robinson Racing Idler Gear: Robinson Racing Hard Steel Idler Gear AX10/SCX10 MIP Drive Shafts: MIP C-Drive Dig Spline Kit (2) (Front/Rear) 32 Pitch Spur & Pinion And Locker's or Spool's in the axles Then move onto Universals/Chubs/Knuckles/Links/Hex's |
02-11-2014, 03:27 PM | #7 |
Please anyone throw out input on anything to add or edit! I more or less copied the wraith thread And I'll update the thread tomorrow when I'm back on a computer (on my tablet while at home) Last edited by Richterat83; 02-11-2014 at 03:30 PM. |
02-11-2014, 03:32 PM | #8 |
I wanna be Dave Join Date: Aug 2007 Location: *
Harley would have a logo and more orange text...
02-11-2014, 03:39 PM | #9 |
how about now... |
02-11-2014, 04:44 PM | #10 |
Newbie Join Date: Feb 2014 Location: Conroe
Subbed
02-11-2014, 05:29 PM | #11 | |
| Re: How to bullet Proof an SCX10 (Based off Harley's Wraith thread) Quote:
Also the mip xref pdf is helpful to cross reference between the various axial models: http://miponline.com/store/media/mip...xref-axial.pdf Good idea for a thread as there are those that don't realize which parts are interchangeable | |
02-11-2014, 08:12 PM | #12 | |
Axial cvd's are garbage even with upgraded pins. If you're already buying alloy C hubs and knuckles just go ahead and do the xr conversion and be done with it. | |
02-11-2014, 09:17 PM | #13 |
RCC Addict Join Date: Dec 2012 Location: Crookston
Nice info in here. Subbed
How to bullet Proof an SCX10 (Based off Harley's Wraith thread) - Similar Threads | ||||
My BULLET PROOF Axial Wraith | flyingrc | Axial Wraith | 12 | 05-26-2014 01:48 AM |
SCX10 Dingo bullet proof transmission | errorbug | Axial SCX-10 | 11 | 07-25-2013 08:17 PM |
