02-18-2014, 09:47 AM | #1 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
| JK RTR articulation problem? Help!!
So I have change my shocks to 110mm King Shocks from rc4wd because stock shocks where leaking and no Im not going back to them. Then I have the level-3 racing droop kit on this because the shocks are so large, my driveshaft angle is okay know with the droop kit. I four-linked the front and I put the axial aluminum links on. What is the cause for the left Front side to articulate around 2 inches but the right Front side articulates around 4-5? (Yes I know the articulation isn't the best but the ride height is the same as stock). Now I can adjust my suspension with the droop kit and the pre-load in the shocks. What would you guys suggest? I have my honcho that has 103mm shocks with the same set-up and it doesn't do this, and my jeep has soft suspension (which I like it that way because my gopro sits on a custom mount up on the roll cage). NOTE: I have a set of 1.9 RC4wd super-swampers on rc4wd rims (used from the honcho). Is the body sitting too low? (Keep in mind that the front body post are at the max) I appreciate the help and support, - axial 4x4 crawler P.S.: If you guys want pictures of what Im talking about then just reply saying "pictures could be useful" or something like that.lol. |
02-18-2014, 01:54 PM | #2 |
Pebble Pounder Join Date: Dec 2009 Location: Vancouver, WA
| Re: JK RTR articulation problem? Help!!
Pictures always help. Is your servo mounted on the axle or is it CMS?
02-18-2014, 02:06 PM | #3 |
Pebble Pounder Join Date: Jul 2013 Location: BFE
You might double check all your link lengths . Ive mistakenly left out a 2mm spacer on mine before and it caused problems with articulation as well as threw my axle out of alignment. A tiny bit of difference in length can be a big deal.
02-18-2014, 05:19 PM | #4 | |
| Re: JK RTR articulation problem? Help!! Quote:
Note that the servo wire is not to short and my steering link is aligned very well. Last edited by axial 4x4 crawler; 02-18-2014 at 05:24 PM. | |
02-18-2014, 05:22 PM | #5 |
| Re: JK RTR articulation problem? Help!! Yes it can, that's a good suggestion. Honestly I never ran into a weird problem like this but I'll double check my links tonight. I know for a fact that I haven't put any spacers on the links but it may be a rod end screw or something like that.lol. I appreciate the help, -axial 4x4 crawler
JK RTR articulation problem? Help!! - Similar Threads | ||||
Wraith rtr esc problem? | fish-hunter | Axial Wraith | 11 | 07-13-2013 06:07 AM |
AX10 Articulation problem... | J.DUKE | Axial AX-10 Scorpion | 22 | 02-11-2009 09:51 AM |
RTR power problem | Jmterminator | Axial AX-10 Scorpion | 7 | 11-22-2008 11:43 AM |
AX-10 RTR tire problem | kafou | Axial AX-10 Scorpion | 7 | 08-25-2008 04:18 PM |
articulation problem | bradahb | General Crawlers | 11 | 08-06-2007 09:16 AM |
