02-20-2014, 08:31 PM | #1 |
Newbie Join Date: Feb 2014 Location: canada
| could any one offer some drive shaft advice?
hey just have a question about the driveshafts on the honcho. well ive lifted mine like 1 or 1 1/2 inches and clocked the axles. the truck has no binding with stock driveshafts but i was worried the stock ones werent going to be long enough and would break so i ordered 155mm junfacs the front one is going to be too long to use so i may have to get a shorter one but the rear one i put on the truck.it works good until i push on all four shocks.when i push all the shocks at the same time it binds the junfac driveshaft but it works fine if i push on the just the rear shocks does any one know how to fix this or could i cut the male end of the shaft so its not in so far?
02-20-2014, 09:11 PM | #2 |
| Re: could any one offer some drive shaft advice?
wow...why did you lift it up so high? thats gotta be unstable..as far as the driveshaft issue, how far in does the male end go?
02-20-2014, 09:41 PM | #3 |
RCC Addict Join Date: May 2008 Location: Southern,WV
| Re: could any one offer some drive shaft advice? |
02-20-2014, 09:47 PM | #4 |
holy bat crap! I didnt even think about it before I said it, or after for that matter lol
02-20-2014, 09:57 PM | #5 |
Rock Crawler Join Date: Jan 2012 Location: Champlin, MN
It almost sounds like the male end is "too long" (insert joke here... and another joke for this joke) seriously though, is it too long when compressed? got a pic of this crazy ride height? |
02-21-2014, 07:25 AM | #6 |
Pebble Pounder Join Date: Feb 2014 Location: gladwin
Okay just built my first scx10 and it is running. Really slow in reverse and fast in forward i am having a lot of diff chatter and it seems that one of the rear tires doesn't seem to be moving at the same speed. I lined up the marks on the drive shaft like the book said i also watched the yuotbe video and made sure the main king pins where lined up to. I have the 55t motor and a taser esc i am going to edit my programming to see if i can make it run the same speed. Any advice on this.
02-21-2014, 07:31 AM | #7 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
if you'll look at the shaft itself...you'll see it has a flat spot on 1 side. halfmoon shaped.. that's whats causing the binding. its not splined so it binds when its on the flat spot upon compression. its a known problem with them... rigs that have a lot of travel have this issue with these driveshafts. |
02-21-2014, 11:24 AM | #8 | |
| Re: could any one offer some drive shaft advice? Quote:
02-21-2014, 11:31 AM | #9 |
is there a way to avoid cutting the dust covers with the mip driveshafts
02-21-2014, 11:39 AM | #10 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
when you got the model, you should have received extra drive shaft parts. Some short and some long. If you need to, you can extend the stock shafts to fit your application. Also, I would go to Lowes and buy a 3-4" 6mm bolt. The kind that is only threaded an inch or so. Cut the threads off and fill the hollow driveshaft with the bolt. cut off the excess. This will strengthen the stock driveshaft and keep it from twisting. Should be fine. |
02-21-2014, 12:36 PM | #11 |
| Re: could any one offer some drive shaft advice? Quote: |
could any one offer some drive shaft advice? - Similar Threads | ||||
Getting the shaft from health insurance, need advice | dont slow down | Chit Chat | 8 | 03-21-2013 01:23 PM |
need drive shaft help | Ruggalo | Formula Offroad | 7 | 10-22-2012 10:29 PM |
best way to join a rwvo drive shaft to the output shaft on the axle | TRAV | Kyosho Crawlers | 12 | 01-29-2012 07:37 PM |
need some advice on drive shafts | rtrim85 | Venom Creeper | 5 | 02-25-2011 07:57 PM |
***MIP C-Drive Drive shaft for the AX10...GIVEAWAY*** | Rockpiledriver | RCP Crawlers | 153 | 07-01-2008 11:18 AM |
