02-23-2014, 08:05 AM | #1 |
Rock Stacker Join Date: Jan 2014 Location: Charlotte
| 5000/6000mah 2s runtimes?
I finished building my scx10 unlimited rubicon yesterday. Tuesday my electronics should be here, i have a Turnigy 6000mah 2s 25c pack, Castle sv3 and 27t motor ordered. From what i have read it looks like i should get pretty long runtimes. How long should i expect out of this lipo?
02-23-2014, 08:07 AM | #2 |
Rock Stacker Join Date: Mar 2011 Location: Westfield
I used to get about an hour or more on my 5000's Sent from my LG-D801 using Tapatalk |
02-23-2014, 08:14 AM | #3 |
Quarry Creeper Join Date: Feb 2012 Location: Arkansas
| Re: 5000/6000mah 2s runtimes?
I'm running a tekin fxr with a 27t on 5300mah 2s and i'm getting around hour and forty five minutes of run time.
02-23-2014, 08:15 AM | #4 |
Quarry Creeper Join Date: Sep 2012 Location: home
Hmmm well if your running stock gearing man you should be getting somthin like 3-4 hours of run time. I run a dynamite 20t with 16t pinion on stock spur and my 2s 5400mah 20c gets near to 4 hours of run time - Richard |
02-23-2014, 08:16 AM | #5 |
Oh yeah.. It also depends on how heavy you are on the throttle and what kind of off-roading you'd be doing too - Richard |
02-23-2014, 08:18 AM | #6 |
Quarry Creeper Join Date: Jan 2013 Location: Spokane
I have a tekin fxr and 35t pro with a venom 3250 2s and I get a hour and a half usually Sent from my SCH-I545 using Tapatalk |
02-23-2014, 08:18 AM | #7 |
I'm running 56,16 or 18,..I'll check my run times next time i go out.
02-23-2014, 12:10 PM | #8 |
Man thats amazing to me, the runtimes these crawlers can get. Ive been out of rc cars for a couple of years, i raced 1/8 electric buggy and we would struggle to get 10 min unless you turned your throttle epa down a good bit. Even 13.5 truck would get 15-20 min. Its very refreshing to me that i will have hours of runtime on ONE lipo pack. 6000mah should be healthy sounds like!!! I plan on running a conservative gearing. Maybe a 16 or 17 pinion with stock spur for now. Im not really interested in speed at all with this truck, i want torque and runtime, thats it! I will gear it so it will scoot along a litte but nothing fast at all. All my electronics are waterproof factory so she will take a dip too after a long run! |
02-23-2014, 04:14 PM | #9 |
I got about 2 1/2 hours out of my setup today.
02-23-2014, 05:14 PM | #10 |
Pebble Pounder Join Date: Jan 2013 Location: Raleigh, NC
Running a Sidewinder 3, 35T Tekin HD motor, stock diff gears, stock 87T spur, stock Ripsaws, either a 15- or 18-tooth pinion, 2S 25C 5000mah - I easily get 3-4 hrs and often more. This is a combo of trail (usually 1-2 miles) then a few hours of crawling. Very very happy with this.
02-23-2014, 05:29 PM | #11 |
Rock Stacker Join Date: Jan 2014 Location: Eagle Rock
i get around 30mins on mine...wish i could get hour run time..i run spc 5000mah 30c 2s.
02-23-2014, 05:42 PM | #12 |
Newbie Join Date: Aug 2013 Location: In my house
One rig is running stock gears with 27t Holmes and Holmes esc with 30c 5200mah and I get close to 3 hours with a mix of crawling and trail running, my other rig has a Castle SCT 3300kv set up with 16t pinion stock spur 35c 3300mah and I get about 2 hours same mix of running. Both batteries are 3s.
02-23-2014, 06:04 PM | #13 |
Quarry Creeper Join Date: Apr 2012 Location: lake wylie
Bone stock set up I have run right at 2 hrs on 2s 25c 5000mah. I finished the run and it hadnt died yet.
02-23-2014, 06:21 PM | #14 |
Quarry Creeper Join Date: Nov 2013 Location: Omaha
yep i usually get 2ish hours off 5800mah with 27t HH combo with mostly trail running
02-23-2014, 07:31 PM | #15 |
Rock Stacker Join Date: Sep 2006 Location: South Texas
Old school integy 35t on stock esc and stock gearing with a 3200 venom 2s and I get like 1.5 to 2 hours run time on a scx jk. Have 3 batts for extra long trail drives
02-23-2014, 08:14 PM | #16 |
Pebble Pounder Join Date: Jan 2014 Location: Staten Island
I have stock Axial electronics and a 4200 2s and im getting a good 1 1/2hr- 1:45, out of one battery, that's probably 30-45 min of high/med speed n the rest crawling... Really depends on what you're doing with the truck. I think considering the size, weight, and cost of the battery, its totally worth it. Long as you use the batteries weight as a benefit in weight distribution -> as in not high in the truck, the heaviness shouldn't be too much a problem when you factor in the excellent run times. |
5000/6000mah 2s runtimes? - Similar Threads | ||||
runtimes. | revoracer99 | Axial SCX-10 | 5 | 02-27-2011 02:21 AM |
