02-24-2014, 05:46 AM | #1 |
Rock Crawler Join Date: Oct 2010 Location: Switzerland
| Racer`S JK G6 team Build
Some of you already know we from the Crawling area and Competition all round the World.... Since there is a Festival in October called " Stonerocker Festival 2014" in Austria with Brian Parker as Special guest and the first Original R.E.C.O.N G6 i have to build something... for the Swiss Team.... Spec on the Build: Front Axle: - Axial SCX 10 Axles - RC Bros Burly Tubes - Axial Overdrive - Hotracing Locker - Vanquish C Hubs - Vanquish Wraith knuckles - XR10 Universals - Costume Servo Link plate Rear Axle: - Axial SCX Housing - Beef Tubes - Axial HD gears - Hotracing Lockers - Costume Link plate Transmission: - Crawlerinnovations HD output shafts - Aluminium gears - Titanium Center Shaft - 56t 32p Spur gear - Slipper removed - Y-Town CFK Motorplate Electronics: - Savöx SW 1210 Waterproof Servo - Castle creations Mambamax one Cell - Castle creations CC BEC 10A - Tekin ROC 412 Brushless motor - Futaba 4 PKS Wheels & Tires: - Vanquish Wheels - Pit bull Mad Beast Tire with Crawler innovations Foams Chassie: - SCX 10 Chassie with some Costume Parts to improve performance Bodie: - Stock G6 Body here the first pictures: for the Basic : First we work on the Chassie : |
03-01-2014, 12:51 PM | #2 |
| Re: Racer`S JK G6 team Build
Time to post up some News on this Build: Today i worked on the New Shockmounts, Link mounts and Batteryholder, for now i just have some GFK Prototypes... Overall View: Here you can see the Channeld front and the Rised Shocktowers.... front Tower includes directly a Battery holder ( ot finished yet), if i want to run a Singel Battery On the Rear Shocktower you can Notice the new upperlink position it`s rised about 15mm and moved back about 5... wich brings alot of problems, but i found a solution to get enough clearance for Motor and Upper links... more on this few Pics later For the Clearance on the driveshaft on the rear i made this little things : Trans Offset Mounts: Here all mounted: With this Little modification all the Problems with the Rear Links are History... And i made some new 4 Link adapters, wich work with VP JK G6 links: Front: Rear: And finaly i cut some batteryplates wich can be mounted on the siderail supports: Alot of infos for today, |
03-02-2014, 08:59 AM | #3 |
Quarry Creeper Join Date: Jan 2013 Location: Spokane
Man all the custom stuff is awesome! BuIlT nOt BaUgHT! |
03-02-2014, 09:55 AM | #4 |
Rock Stacker Join Date: Mar 2012 Location: SoCal
Oh, this is gonna be GOOD! ...go RACER go!...
03-02-2014, 01:09 PM | #5 |
| Re: Racer`S JK G6 team Build Thanks i like to build my own stuff, and use alot of existing parts.... Thanks i give my best.... Goal is --> Outside a Scaler, inside a performer Today i went over for the first Version of the CFK frame.... there will be 3 Chassie made for now to test every thing... if there is a request on them i?m thinking about getting a Bluestar and make them avaible for all.... but first lets Build and drive it.... Here some Picutres of the final Product: Top view: Side view: At Full compression: Detail on the rear: you can see the "doublers" on the upper links wich should help to clear the Frame and make it more strong.. also the Electronic tray ( final version will have a Carbon plate on it, and the Body mounts are Screwed to the CFK side plates front and rear Detail on Front: Battery tray for singel Battery setup Next steps are : - Crossbraces - Sway bar on the Rear Axle |
03-02-2014, 06:07 PM | #6 |
Stupid question but why is everybody putting sway bars on their scalers? BuIlT nOt BaUgHT! |
03-02-2014, 09:33 PM | #7 | |
I wanna be Dave Join Date: Oct 2007 Location: 801
| Re: Racer`S JK G6 team Build Quote:
a rig at high speed with a sway bar is hands down more controllable and steady. looking awesome manu! I am dying to build a g6 and now I see this.... your not making this decision easy for me | |
03-03-2014, 04:01 PM | #8 |
Very interesting way to go about things. I like it |
03-05-2014, 05:35 AM | #9 |
Quarry Creeper Join Date: Jun 2010 Location: Vienna, Austria
I love where this is going!
03-05-2014, 06:13 AM | #10 |
| Re: Racer`S JK G6 team Build This is amazing stuff Manu, one of the 3 test chassis is for me right? Once again super clean work from you my friend, subscribed for sure. |
03-05-2014, 09:50 AM | #11 |
Pebble Pounder Join Date: Sep 2013 Location: Michigan
Wow this is crazy, I love the c channel in the front how much more flex dose it offer I see the full drop is great
03-06-2014, 08:04 AM | #12 |
Newbie Join Date: Aug 2011 Location: italy
A really great job! don't stop Manu! the latest updates are simply fantastic! little curiosity, the Beef Tubes in the rear also compensate the larger width of the front? |
03-06-2014, 11:32 AM | #13 | |
More updates soon | |
03-12-2014, 12:20 AM | #14 |
Pebble Pounder Join Date: Mar 2010 Location: Muri Switzerland
New parts have arrived |
03-12-2014, 04:29 AM | #15 |
Quarry Creeper Join Date: Nov 2012 Location: Michigan
Looks great so far.
03-12-2014, 01:19 PM | #16 |
Today i get a nice Package form Crawlerinnovations : Pit Bull Mad Beast with wild duce Foams Servo took his place on the Rig and Protosteering done : very tight fit but clears nice also worked on the Swaybar mount on the rear Axle, parts i used for this are: - Vanquish AX10 Shockmount Razors - D- Lux Swaybar Kit - Costume CFK holder it needs some small adjustments but i think should work: And here test fit of the Spare tire.... Next i have to work on a spare tire holder...... and waiting for some VP wheels |
03-12-2014, 05:37 PM | #17 |
I wanna be Dave Join Date: Dec 2009 Location: Lady Lake, Fl
awesome build Beautiful work
03-13-2014, 01:56 AM | #18 |
Amazing Steering! How wide is the front? Cheers Daniel |
03-13-2014, 04:53 AM | #19 |
Pebble Pounder Join Date: Feb 2014 Location: Hampton Roads
Agree, amazing steering, what steering setup is that? Sent from my SGH-M919 using Tapatalk |
03-13-2014, 07:09 AM | #20 | |
| Re: Racer`S JK G6 team Build With Stock Axial wheels 265mm.... Try to narrow it a bit when i get my VP wheels Quote:
-RC bros burly spline tubes - Vanquish Wraith C hubs - Vanquish Wraith Knuckles - XR10 Universals | |
Racer`S JK G6 team Build - Similar Threads | ||||
Team BWD - Team East Coast RC - MRC build | limited77 | Losi Mini-Rock Crawler | 49 | 03-19-2012 06:19 PM |
want to build a rock racer | ottoride | Kyosho Crawlers | 9 | 03-11-2012 08:32 AM |
The XR from Racer, a Swiss Build | racer_zh | Axial XR10 | 26 | 08-14-2011 01:33 PM |
2.2 Rock Racer build | tubed-n-lubed | General Crawlers | 31 | 02-04-2010 12:50 AM |
