02-27-2014, 06:41 PM | #1 |
Rock Stacker Join Date: Jan 2014 Location: Charlotte
| Castle SW3 and Axial 27t jerky?
I wired up my new SW3 and axial 27t motor tonight, calibrated it and all correctly.... Motor runs but is very jerky and when i hold down full throttle the motor just stops. I used the reversing wiring diagram in the castle menu, white wire not used. I have calibrated it several times now, reversed polarity, nothing. Any advice is much appreciated!!
02-28-2014, 05:12 PM | #2 | |
Quarry Creeper Join Date: May 2012 Location: Industry
| Re: Castle SW3 and Axial 27t jerky? Quote:
02-28-2014, 09:49 PM | #3 |
Quarry Creeper Join Date: Sep 2011 Location: hemet
Juttsvw is probably right, or it could act that way if it is set for lipo and you aren't running one. What kind of servo are you running? IF it is a very high torque, it can cause mischief. I just pulled my hair out getting one to work. Even with a bec it wouldn't operate correctly. I ended up setting the voltage a little lower on the bec and that solved the problem. Totally a mess at 7 volts, went down to 6 and everything is fine.
Castle SW3 and Axial 27t jerky? - Similar Threads | ||||
Should I bother? (27t axial to 27t HH) | Chisholm | Electronics | 4 | 02-04-2014 01:11 PM |
Doin the jerky jerky | Nylintbucket | General Crawlers | 8 | 10-20-2009 07:43 PM |
