![]() | #1 |
Newbie Join Date: Feb 2014 Location: Netherlands
I hear the noise only when driving up and down of something like in the video. https://www.youtube.com/watch?v=ljeI...e_gdata_player Anyone can help me? ?? |
![]() | #2 |
MODERHATER™ ![]() Join Date: Nov 2005 Location: Colorado
Take it apart and have a looksie! ![]() |
![]() | #3 |
I wanna be Dave ![]() Join Date: May 2006 Location: FOUR 8 OH
Only way to tell is to tear into the axle and inspect. It is either the locker or the gears.
![]() | #4 |
![]() | #5 |
I wanna be Dave ![]() Join Date: Jul 2009 Location: Rancho Relaxo. California. USA. Earth.
Disconnect the driveshafts and if the noise still happens, chances are its in the tranny. And vice versa if the noise stops, more likely the axle(s). As was said, only proper way is to start some disassembly and have a look at all your gears. If you haven't done the bearings in awhile or replaced the stock gears with the hardened versions, it may be a good idea to do so. The stock gears will deform easily with even a heat gun applied to them... found that out the hard way. |
![]() | #6 | |
| ![]() Quote:
I think I am going to have to buy new gears, its coming from the gears that go from the big gear to the drive shafts so you have motor with a gear on it that is on a big gear, those are not the problem but the ones that come after those. Can I just keep drivin? Or as long as it takes to get the new ones? Cuz il have to order them prob. | |
![]() | #7 |
Pebble Pounder Join Date: Jan 2014 Location: Staten Island
It's the gears in the tranny then right? the ones that are inside the plastic case. You could keep running it i probably would, but you are going to need new gears, and there is a chance youll burn out the bearings, but a new set is probably $20, you should probably order them with the hardened tranny gears in any case..
![]() | #8 | |
| ![]() Quote:
So if i buy such a plate thingy why dont i buy one of these? https://store.rc4wd.com/mobile/product.asp?itemid=2463 Is that smart plan? Or nor and why or why not? Anyone has excperience with one? And wich is best to buy if you also look at price? And about these bearings? Why do they go broken? They melt? And wich bearings would you suggest? Edit2: I see alot of people that dont have the plastic cover over their gears that come from the motor an the big gear thing. Why is that? And i think my slippery clutch (is that right how i write it) isnt working it wont just slip motor looses it. And if the engine cant win it how bad is it to keep trottling? Last edited by UNDEAD_DC; 03-01-2014 at 05:39 PM. Reason: stupid not well thinking reaction. | |
Axle gear noise | canadianbacon | Axial SCX-10 | 4 | 10-20-2012 09:40 PM |
Clicking noise coming from transmission-Help please | promatchrcr | Team Losi Comp Crawler | 13 | 01-20-2010 03:35 PM |
axle noise | IDnewcrwlr | Axial SCX-10 | 7 | 09-18-2009 09:41 PM |
Axle Noise | loanshark | Tamiya TLT Crawlers | 4 | 03-02-2007 02:43 PM |
