03-02-2014, 08:16 AM | #1 |
Rock Stacker Join Date: May 2011 Location: quebec city
| hd bevel gear in scx10 choice
Hi i check for change my bevel gear in my rigs now iu have the original but its was used a little bit lol < i put a goat 3s 21.5t combo in and ride with 3s lipo i found its was slow a little bit i check for put the hd bevel gear ax30401 its the 14/36 ratio someone have it ? your impression please < thx a lot and sorry for cheap englsih |
03-02-2014, 08:24 AM | #2 |
| Re: hd bevel gear in scx10 choice
put another way, I wonder if I'm better to put the bevel gear 13/38 and mount the 23t or 24t pinions was on my engine or I better put the bevel gear 14/36 and lower my pinion is 17t now I have 13/38 bevel pinion and 20t I want a little more full speed (very useful when one has need of wheel spin)
03-02-2014, 08:32 AM | #3 |
what are you doing with the rig? crawling, trail running or a mix of both? 23t/24t pinions are going to cause overheating issues with the motor...i run 13/38 stock gears in diffs and 56/11 spur gear and pinion on 3s with a 30t holmes hobbies torquemqster pro motor. Its top speed is way faster than I can walk and has no issues with wheel speed being inadequate....leave the 13/38 in it and go with a 16t pinion for starters...watch temp on the motor, dont let it go over 160 degrees F.
03-02-2014, 08:50 AM | #4 |
I made a mix of both slowly crawling and walking trail with rock roots I just want a little more speed |
hd bevel gear in scx10 choice - Similar Threads | ||||
Bad Mesh on bevel gear and diff gear out of the box? | Elliott000 | Axial SCX-10 | 3 | 08-19-2011 06:37 PM |
whats the toughest bevel gear for scx10 | bro_die | Axial SCX-10 | 4 | 06-04-2011 06:25 AM |
scx10 bevel gear suggestion | bro_die | Axial SCX-10 | 5 | 03-07-2011 05:03 PM |
