03-02-2014, 01:30 PM | #1 |
Rock Stacker Join Date: Jul 2011 Location: Coeur d'Alene
| Scx10 front diff help
So, after buying back my scx10 that I sold to a friend I have had to do a ton of work on it. But yesterday I rebuilt the axles and the rear one turned out great but my front I'm getting a little chatter. I did upgrade to the HD ring and pinion and wonder if I just wasn't generous enough with the gear lube? I have been searching but the only info I can find is for a wraith. Could anyone offer a suggestion or maybe just let me know if I need to get in there and add more grease? thank you
03-02-2014, 01:38 PM | #2 |
| Re: Scx10 front diff help
How does it feel? If it feels notchy like you can feel each tooth making contact you're too tight. If it's got too much slop it'll make noise too. If you think you didn't grease it enough then open it up and fix the issue.
03-02-2014, 01:56 PM | #3 |
Alright. While I got ya here about how much grease would you recommend? and if I need to adjust it how would I do that? I know they say to use shims but where at? Sorry about all of the newb questions.
03-02-2014, 02:01 PM | #4 |
I like to make sure the gears have a nice coating of grease on the wear surfaces. A little more than that is fine. There are shims made for a traxxas application that work great. They are about 8mm OD and 5mm ID made of teflon. If the pinion has slop while turning odds are you need a shim or two behind the head of the pinion to move the gears closer together.
03-02-2014, 02:10 PM | #5 |
Thanks. Ill try it tonight and see if I can fix the problem. Soon as brown santa arrives I can lock myself in my hobby room and have a field day. Junfac shafts. Look like mip clones to me. proline swamper xl's hd gear set in the front axle including new housing integy 45 turn motor robinson hardened diff gear in the transmission replacing all frame braces and shock mounts new battery rc4wd cms and upgrading all links and steering to TR metal links.
03-02-2014, 02:15 PM | #6 |
While you're in there changing the idler gear in the trans out for a metal version is more important than the lower gear since the idler takes more abuse and is more prone to stripping the teeth off.
03-02-2014, 02:19 PM | #7 |
ya I thought about just going full metal in the tranny. plus it will add some weight. I know its harder on parts but I didn't like how bouncy it was stock so I am trying to make it a little heavier so it might drive a little more scale
03-02-2014, 02:26 PM | #8 |
The weight is minimal, heck I'm running a RR steel idler on a RR aluminum diff gear on one rig with great results. The other two have RR steel idlers and one piece lower gears. It's all about durability to me. My junk is all severely abused so strength is key.
03-02-2014, 02:37 PM | #9 |
yeah. I think ill investigate that idler gear next month or something after my credit card cools down lol. got any pics of your rig?
03-02-2014, 03:06 PM | #10 |
The latest family portrait of the main rigs. Fofftarded II, crawler, scx morphodite and the exo. |
Scx10 front diff help - Similar Threads | ||||
Front Diff | blumaro | Vaterra Twin Hammers | 4 | 02-28-2013 05:42 PM |
front diff? | hende | 1:1 Full Size Vehicles | 3 | 10-22-2012 04:10 PM |
independent front suspension and front diff build | canadian scx10 | Axial SCX-10 | 1 | 02-13-2011 07:52 PM |
front diff | Oze30 | Axial AX-10 Scorpion | 2 | 12-22-2007 02:41 PM |
