03-04-2014, 08:46 PM | #1 |
Quarry Creeper Join Date: Jan 2013 Location: Spokane
| Scx10 axle ?
I built my scx10 jk kit and when I pick it up and pull the trigger just enough to get the wheels to spin the axles chatter almost like horrible wheel hop... drive lines are phased correctly and axles and transmission spin free when not hooked to anything. Any suggestions? BuIlT nOt BaUgHT! |
03-04-2014, 10:28 PM | #2 |
03-04-2014, 10:38 PM | #3 |
Says video is private..cant see it
03-05-2014, 12:53 AM | #4 |
Pebble Pounder Join Date: Jan 2014 Location: Staten Island
| Re: Scx10 axle ?
Holy crap man i was able to see it but im logged in to youtube through my google plus account. Its really bad worse then i thought in your description damn i wish i could help you. I'd say from the way the wheels are stuttering the gears are skipping at some point i remember when my spur and pinion were close but not close enough id have the same issue the spur would spin and periodically it would just stop while the pinion kept moving..that's the only thing i can think of, the bevel gears aren't meshing right.
03-05-2014, 04:08 AM | #5 |
Newbie Join Date: Mar 2013 Location: Elkins, AR
| Re: Scx10 axle ?
My G6 had a little bit of that. The pinion/diff gear mess had some tight spots causing the jerking. I loosened the diff housings bolts some and drove it around for a while. A few packs it is mostly gone. Just make sure the bolts holding the 2 axle halves are not too tight. It doesn't take much to hold it together. Also possible that the inner bearings for the diff pinion is not seated correctly. Factory mold flashing may have been left in where the bearing goes holding the bearing from seating correctly. Hope that helps. |
03-05-2014, 05:34 AM | #6 |
Pebble Pounder Join Date: Oct 2013 Location: Miami
| Re: Scx10 axle ?
I read somewhere that you have to line up the drive shafts end so that the tick marks that was molded onto the parts line up. Hope that helps...
03-05-2014, 08:50 AM | #7 |
Rock Stacker Join Date: May 2013 Location: Appalachia
| Re: Scx10 axle ?
Agreed. Your drive shaft pins aren't aligned. I rebuilt my rear end this weekend and forgot about drive pin alignment. It chattered like crazy. I lined them back up. Problem solved.
06-06-2014, 01:50 PM | #8 |
Newbie Join Date: Apr 2014 Location: Portland
| Re: Scx10 axle ?
Did this get figured out? I have the exact same problem and I cant seem to figure it out.
06-06-2014, 02:08 PM | #9 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
| Re: Scx10 axle ?
Actually the lines on the shaft doesn't matter, its the cross pins that need to be lined up. Install the shafts with the pins both laying horizontal to the ground.
06-06-2014, 02:19 PM | #10 |
Newbie Join Date: May 2014 Location: Tomball
Mine does the same thing 2 weeks old , drive shafts had too much of an angle . Made aluminum suspension links to change the pitch of the drive shafts , now it all went away
06-06-2014, 02:21 PM | #11 |
Rock Crawler Join Date: May 2012 Location: Columbus
| Re: Scx10 axle ?
I had the same problem and it was so bad i mailed it back to axial and they couldnt figure it out eather so they sent me a RTR honcho with TREK batteries
06-06-2014, 02:35 PM | #12 |
Quarry Creeper Join Date: Nov 2007 Location: Orygun
| Re: Scx10 axle ?
I'm apparently stupid, but why does the orientation of the pins being lined up matter on a u-joint? I've never worried about that, not had any of these issues.
06-06-2014, 02:36 PM | #13 |
Newbie Join Date: Jun 2013 Location: Lakeside
I had the same problem. Re align drive pins. No problem any more. Sent from my SAMSUNG-SGH-I337 using Tapatalk |
06-06-2014, 09:04 PM | #14 |
Rock Crawler Join Date: Aug 2012 Location: Port St Lucie
| Re: Scx10 axle ?
I wish I would of found this thread sooner. I just bought RR steel gears, Axial HD bevel gears, Locked up spools, Axial front cv joints & MIP drive shafts. I still had the problem. I checked the pins & the front drive shaft was off by 90 degrees. Realigned and its perfect. Thanks guys.
06-06-2014, 09:21 PM | #15 | |
I wanna be Dave Join Date: Dec 2009 Location: Lady Lake, Fl
| Re: Scx10 axle ? Quote:
06-08-2014, 08:25 AM | #16 |
I'm happy with the upgrades, it needs to strong for the Coven Quest! Sent from my iPhone using Tapatalk |
Scx10 axle ? - Similar Threads | ||||
scx10 axle? | Juicebag31 | Axial SCX-10 | 3 | 06-04-2013 02:59 PM |
SCX10 Axle Help | cwoods333 | Newbie General | 6 | 06-01-2013 10:11 AM |
scx10 axle help! | theloudone | Axial SCX-10 | 5 | 11-30-2012 12:12 PM |
RC Axle Master Axial AX10/SCX10 Rear Straight Axle Kits | LetsHandleit | Axles, Trannys, T-case | 41 | 06-24-2012 06:57 PM |
scx10 axle ? | 4ONDFLR | Axial SCX-10 | 3 | 02-03-2009 04:08 PM |
