03-13-2014, 10:00 AM | #1 |
Rock Stacker Join Date: Mar 2013 Location: Salt Lake City
| Bent driveline components
Hi all. I have been trying to figure out some issues with my honcho for a while and decided to consult the interwebs. Something is bent in my driveline, but I'm not quite sure what to replace. My suspicion is that it's something in the transmission. My reasoning behind this is because there is a wobble in both output shafts on the tranny. The wobble is bad enough that the truck will hesitate as I crawl at low speeds. At high speeds it turns into a disconcerting vibration. I may make a video if my explanation is unclear. My question is, what should I replace? Thanks all. Sent from my iPad using Tapatalk |
03-13-2014, 10:03 AM | #2 |
| Re: Bent driveline components
Crack open that tranny and check it out. |
03-13-2014, 10:07 AM | #3 |
Quarry Creeper Join Date: Mar 2009 Location: Central WA
| Re: Bent driveline components |
03-13-2014, 11:07 AM | #4 |
I forgot to mention that I have had it open before. Nothing looks obviously wonky. It's been confusing/frustrating. Sent from my iPhone using Tapatalk |
03-13-2014, 11:22 AM | #5 |
Pebble Pounder Join Date: Dec 2008 Location: California
I've been dealing with this recently myself. My guess is that my bearings are shot so I ordered a new set for the transmission.
03-13-2014, 11:36 AM | #6 | |
| Re: Bent driveline components Quote:
Output shafts are securely fastened to the main tranny gear? Bearing surface on the output shaft isn't damaged? Output shaft supporting bearing in the tranny housing is tight and spins smoothly? No wobble or movement of the race? Driveline is properly secured to the output shaft and the driveline itself doesnt wobble when secured? Transmission housing is intact? | |
03-13-2014, 11:49 AM | #7 |
My bet is that the drive shafts are not aligned properly. the DS's universal pins need be in line with each other. there are ^ marks on the plastic bodies of the shaft to align. If the marks are ground down or not found... then align the universal pins so that they align with each other. It is called phasing. |
03-13-2014, 11:58 AM | #8 | |
03-13-2014, 03:14 PM | #9 | |
Going to check this out later today. Will report back. Thanks all! Sent from my iPhone using Tapatalk | |
03-13-2014, 04:55 PM | #10 |
Aligning the marks on the drive shafts definitely took the crazy axle hop out of the driveline. It's so much better. The tranny still probably needs some love, but now at least I don't feel like the truck is going to vibrate its self to death. Thanks!! Off hand, does anybody know the front upper and lower link lengths for a honcho (using axial's metal links?) Right now I have 91mm lowers and uppers made of a 25mm length combined with the 60mm length. Doesn't seem right. Sent from my iPad using Tapatalk |
Bent driveline components - Similar Threads | ||||
NEED HELP with updated driveline components | kredfearn | Venom Creeper | 4 | 02-19-2012 08:47 AM |
Bent links or not bent likes that is the question? | Ktbone | Newbie General | 67 | 01-06-2012 05:10 AM |
How Bent is Bent? (Trans Input shaft) | Grouper | Axial AX-10 Scorpion | 7 | 01-06-2012 01:32 AM |
Buying Components? | du4x4 | Electronics | 6 | 05-21-2011 09:24 AM |
components | SlammedMini469 | Electronics | 2 | 02-20-2005 01:03 AM |
