03-15-2014, 08:15 PM | #1 |
Pebble Pounder Join Date: Feb 2014 Location: NH
| Diff and Driveshaft Skid
I always thought the front cup on the drive shaft joint, with its flat face and edge, looked like it was just asking to get gashed up and caught by rocks. A built a skid to allow the front axle and drive shaft joint to slide easily over obstacles. This prototype is made out of aluminum. Once the snow melts, and the rocks are more exposed, I'll be able to do some real testing. I could make it from steel, which is generally preferred for skid plates, but I think aluminum makes more sense in this case, as it will occasionally contact the drive shaft ring and I'd rather the wear was on the skid than the ring. Thoughts or comments are welcome. |
03-15-2014, 08:54 PM | #2 |
Rock Stacker Join Date: Nov 2010 Location: WNY
| Re: Diff and Driveshaft Skid
How is it attached? Looks nice.
03-15-2014, 10:02 PM | #3 |
Pebble Pounder Join Date: Jan 2014 Location: Staten Island
I like this idea looks like flashing am i right? Its thin but it takes scratches and scrapes pretty well and its smooth which helps! You should also invert your driveshafts so the smooth side is on the bottom closest to the rocks Keep the engineering coming! I like the snow chains btw
03-15-2014, 10:36 PM | #4 |
Quarry Creeper Join Date: Mar 2009 Location: Central WA
Just adjust your link lengths and roll the axle up (IE adjust the caster). Provides a much better pinion angle, gets it out of the rocks, and you maintain plastic to rock contact which is the slickest imo.
03-16-2014, 06:16 AM | #5 |
Rotating or" clocking" the axle would also decrease steering efficiency. Tstmonkey, its currently attached in the front with E6000 adhesive. The rear wraps around the drive shaft. The E6000 seems to hold it quite well, shouldn't be affected by water or mud, and is still pretty easily removable. |
05-12-2014, 07:25 AM | #6 |
Finally got a chance to test this on some rocks (broken chunks of cement, actually). It was working great and sliding smoothly over obstacles, until it caught on a jagged edge, in reverse. It popped the skid right off! Evidently, E6000 wasn't quite up to the task. I still think the idea is solid, though. |
05-12-2014, 07:33 AM | #7 |
Quarry Creeper Join Date: Jul 2013 Location: Toronto
there is a guy on ebay selling skid plate for the axle's Junfac J80029 Skid Plate FOR SCX10 AX10 Axle | eBay |
05-12-2014, 07:50 AM | #8 |
Yes, but the reason for building mine was to protect the lower joint on the drive shaft.
05-12-2014, 08:59 AM | #9 |
I am testing a prototype I built out of galvanized steel...my driveshaft joint is clocked up enough there is not going to be any issues with damage as the lower links hit on obstacles instead of the driveshaft joint. this is proving out to be very good at what I intended it for and will make a final version soon I think. |
05-12-2014, 06:01 PM | #10 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Re: Diff and Driveshaft Skid |
05-13-2014, 08:06 AM | #11 |
I wasn't aware that it was adjustable.
05-13-2014, 08:18 AM | #12 |
RCC Addict Join Date: Apr 2011 Location: San Diego
05-13-2014, 10:13 AM | #13 |
Exactly. I prefer to do what I can with what I have / can make. Building a $0.99 skid plate, verses building new links and buying new chubs. Plus, it looks to me that rotating the axle may cause some clearance issues between the servo and the frame braces. |
Diff and Driveshaft Skid - Similar Threads | ||||
whats the Diff, between maxx 3.3 diff and revo diff? | 12voltfun | Traxxas Crawlers | 2 | 06-06-2009 09:16 PM |
AX10 Diff Locker working on Wheely King Diff | rcpaintworks | HPI Wheely King | 6 | 08-18-2007 09:13 AM |
