03-15-2014, 10:42 PM | #1 |
Pebble Pounder Join Date: Jul 2012 Location: SJ
| 2.2 Tires and Motor/Pinion
hey guys i have some axial rock lizard tires on my SCX10 right now. They are a little over 5" tall. I have stock electronics and motor. My question is, what should i change to accommodate the 2.2 tires? Change the pinion gear? or change to a 55T axial motor and leave the 20T pinion gear? Thanks, other options are welcomed |
03-15-2014, 11:31 PM | #2 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Re: 2.2 Tires and Motor/Pinion
I'm assuming your gearing is stock, too? Pick up a good handful on pinions, 10T-16T. Just keep an eye on your motor and ESC temps. |
03-16-2014, 09:12 AM | #3 |
| Re: 2.2 Tires and Motor/Pinion |
03-16-2014, 09:25 AM | #4 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
Well what do you want? More speed or better climbing ability?
03-16-2014, 09:51 AM | #5 |
03-16-2014, 01:53 PM | #6 |
Do you have a 27turn or 20turn motor? Either way, it's do as suggested, pick up some motor pinions from 10t-16t and try them out. If you put in a 55turn motor, you'll want to upgrade your battery to a 3cell Lipo, but then you'll need new electronics. |
03-16-2014, 02:30 PM | #7 |
Rock Stacker Join Date: May 2010 Location: Bluefield,WV
If you have a 20 or 27 turn in there now a 55t will really slow things down and gear you more towards just having just a crawler. I would try some different gearing first. Sent from my iPhone using Tapatalk |
03-16-2014, 02:48 PM | #8 |
ok i will try different pinions. What pinions will fit my scx10 because i see different style ones out there
03-16-2014, 03:02 PM | #9 |
RCC Addict Join Date: May 2008 Location: Southern,WV
| Re: 2.2 Tires and Motor/Pinion 48p which means 48 pitch...That' the size and angle of the teeth on the gears. If you still have all stock gearing you have a 87T spur gear. So a 15t or 16t pinion are probably going to be in the sweet spot.IMO....I'd say 16t. but that's me.A 16t's ratio will give you an ok speed with good torque to get those big tires moving.. Someone else may have another idea though.
03-16-2014, 06:25 PM | #10 |
Newbie Join Date: Mar 2014 Location: Soldotna, Alaska
Running 2.2 TSL's, Axial 55t motor w/ 20t pinion. Decent speed and climbs really well with tons of torque. Ran 27t motor with 14t pinion and it was pretty good, way more torque with the new motor though.
03-16-2014, 11:58 PM | #11 |
Rock Crawler Join Date: Apr 2009 Location: bend
For my daughter waith i changed the spur to 87 and the pinion to 14 with the stock motor and it has lasted over three years. I also put MT Claws on her rig which are 5.75 inches tall.
03-17-2014, 08:02 AM | #12 |
Just went to the hobbie shop and bought a 14t pinion. I will install and see how it perform
03-17-2014, 08:34 AM | #13 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
Spur Larger for slower speeds, Smaller for for faster speeds. Pinion Larger for faster speeds, Smaller for slower speeds. |
2.2 Tires and Motor/Pinion - Similar Threads | ||||
Which motor/pinion | Briguy-01 | Team Losi Comp Crawler | 17 | 02-27-2014 05:57 PM |
Motor or Pinion first? Which is better? | DieCastoms | General Crawlers | 41 | 05-21-2013 05:41 AM |
what motor pinion | damige jnr | Newbie General | 3 | 04-13-2010 01:44 AM |
DNA motor mount. What motor/pinion fits. | sdcrawls | HPI Wheely King | 5 | 04-11-2010 06:23 PM |
motor and pinion ? | moparman89 | Tamiya Clod Buster | 0 | 02-18-2007 08:11 PM |
