03-18-2014, 08:06 AM | #1 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
| Thinking about dropping a VXL in a JK rtr, what do you think?
Hello everyone, So I know this question has been asked several times but I just cant get the right answer. I have a brushless VXL system in my parts box from my slash 4x4 lcg when I switched out the esc/motor. I would like to drop this system into my jeep rtr and since I mostly do mudding with the jeep it would give it some serious wheel speed! I DO NOT rock crawl with this, thats what my honcho and ridgecrest is for! Bottom line, Would this work? I would put a 16t 48p pinion on this and also I mirrored my tranny so it wouldn't go crazy if ya know what I mean. Would this damage the stock transmission gears if I go mudding and on water runs? I have waterproofed the entire truck for water, and I have already taken it mudding three times! I understand that putting a brushless system in this truck is insane but then again I would like to see the mud fly. Thank you in advance, - axial 4x4 crawler |
03-18-2014, 08:10 AM | #2 |
Quarry Creeper Join Date: Mar 2013 Location: Armpit of Michigan
I can promise you plastic gear trans will be nothing but a memory. your stock plastic driveshafts will be no more but other than that you'll be good
03-18-2014, 08:19 AM | #3 |
| Re: Thinking about dropping a VXL in a JK rtr, what do you think?
Well I could do the good old trick with the steel rods, shoo gue it into the stock driveshaft and call it that. Should I buy some robinson racing gears for the transmission? Note: If I get some robinson racing gears (the solid steel outdrive gear) I will need grub screws to hold the driveshafts in. Trust me with the solid steel rod in the driveshaft, it worked with my wraith running a tekin 10.5t and 3s so it has to work for the jeep with a VXL. Thank you for your time, I appreciate it, - axial 4x4 crawler
03-18-2014, 08:28 AM | #4 |
I have been running 3s on an scx for over a year and all i did to the Tran is install the hot racing steel gear set
03-18-2014, 08:34 AM | #5 |
Really ok that sounds good, I will look into that Hot Racing gear set.The only thing is that those Robinson Racing gears can probably take more abuse, just saying. I've heard bad things about Hot Racings' products, the only thing I own of them are some diff covers for the ridgecrest.lol. What type of motor/esc are you running in your scx-10?
03-18-2014, 08:37 AM | #6 |
I hate hot racing but these gears have been solid. I have done everything from FOFF to mud racing with them on 3s with a 3800 kv system
03-18-2014, 08:44 AM | #7 | |
| Re: Thinking about dropping a VXL in a JK rtr, what do you think? Quote:
ni-MH just because I don't really want to put my good 2s or 3s batteries in it.lol.Thank you for the suggestions, I appreciate it. - Axial 4x4 crawler | |
03-18-2014, 09:07 AM | #8 |
I ran a VXL system in an scx-10 for a while. It worked pretty good. I geared mine 87/12 and it even crawled O.K. I ran it on 3s AND tranny still had original plastic gears. I didn't drive it like an idiot and nothing ever broke. It wasn't until I threw on sand paddles and went to the gravel pit that I stripped out gears in tranny.
03-18-2014, 09:09 AM | #9 |
There is a difference between that and planning on throwing mud. I don't drive mine like an IDIOT but I'm not afraid to break it either
03-18-2014, 09:20 AM | #10 | |
03-18-2014, 06:44 PM | #11 |
Just for peace of mind these days I install HR steel tranny gears from the start just so I don't have to crack the cases open ever again. It's worth the $28 (if you have it) A couple of my trucks it probably wasn't necessary but oh well. Like I said, it's nice to have less to worry about out on the trails. I forget how to set the cutoff.. You don't have a manual? You should be able to find what you need to know on the Traxxas website. |
03-18-2014, 07:20 PM | #12 |
if you are going to mud with this rig you most certainly will destroy the plastic gears as the mudding will put a tremendous load on the driveline, especially running a vxl3s system. I am running a castle 3800kv in a wraith 1.9(which is a little more powerful than the vxl3s)...same driveline..it is already distorting the driveshafts and i did the mod for them..its distorting where the driveshaft mounts to the collar/yoke. if you really want to have some serious mud fun, get MIP driveshafts, hardened steel gears for the trans, upgraded output..and a 32p spur/pinion setup...my castle stripped out the 48t spur quickly in the clay/mud we have here...and yes mesh was set properly. do that and then have a blast...it is fun as hell seeing mud roostertails from all 4 tires! |
03-19-2014, 10:31 AM | #13 |
Ok well I can always change out my driveshafts if need and I have plenty of extra driveshafts laying around (stock plastic ones).but with 32p gearing, it's annoying to put this on although its a good suggestion. Your right about the 3800kv setup being stronger cause I put that system in my slash and took out the vxl system, and that is running mod1 gears. That 3800kv motor I have has a 5mm pinion shaft so pinions are a bit harder to find but anyways with the jeep, it is built for heavy mud and water, the mud I go through done here in Missouri is watery and not thick unless you make it that way.lol. I've taken my jeep through water up to the hood and mud that goes up to the axles but the jeep went through that stuff with no problem and personally MIP shafts are not needed for a scaler, for a slash sure but not in a off-roader, just my opinion. Hell if viper made waterproofed stuff I would sell the vxl and go to a viper 550 brushless motor and there only for 120.00 and those have more power than a 3800 KV 4-pole has!! The vxl is only a 2-pole so the torque is a problem but like I said a 550 would be way better but its not waterproof. Thank you for your time, - axial 4x4 crawler
03-19-2014, 10:34 AM | #14 | |
03-19-2014, 12:59 PM | #15 | |
03-19-2014, 01:06 PM | #16 |
"personally MIP shafts are not needed for a scaler, for a slash sure but not in a off-roader, just my opinion." thats fine to have your opinion, I have a scrap box full of stock driveshafts that are twisted from my scaler and my wraith. My opinion is they are needed for my driving style and terrain I have here. the scaler has a holmes hobbies 30t torque master pro and it has twisted more than one stock axial WB driveshaft on 3s. I beat the crap out of my rigs and upgrade as necessary. its all about the fun |
03-19-2014, 01:29 PM | #17 | |
03-19-2014, 01:34 PM | #18 | |
03-19-2014, 02:15 PM | #19 |
no problem, like I said its all about the fun |
03-20-2014, 09:53 AM | #20 |
Rock Crawler Join Date: Jan 2012 Location: Mcallen, Tx
one word.. Kaboom..!
