03-20-2014, 12:10 AM | #1 |
Newbie Join Date: Mar 2014 Location: Makakilo
| SCX10 underdrive gear making clicking noise....
So I bought the axial overdrive and underdrive gears. So the front 36/14 gear works perfectly fine. But the back 43/13 gear makes this clicking noise when slowly going foward and backward. Took it apart and put it back together again and still the clicking noise. I stuck the stock gears back in and there was no problem at all. Cleaned and greased, gasket is in between the locker and gear. I just don't know what else to do. I'm beginning to think my 43/13 gears are defected. So i was wondering if anyone had any other ideas as to whats making the noise before I go and buy a new set.
03-20-2014, 01:42 PM | #2 |
Newbie Join Date: Mar 2014 Location: Rockaway
| Re: SCX10 underdrive gear making clicking noise....
I am having the same problem with my stock gears, just started my build and cant get past building the axles. Everything is nice and smoothe until I put the case together, both axles. Read 100 posts, watched 100 videos, I am doing the exact same thing but I cant get rid of this clunking |
03-20-2014, 10:35 PM | #3 |
Pebble Pounder Join Date: Dec 2013 Location: Burbank
Both of you, run it a bit. I bet it goes away after a pack or two run through the car. Mine did that and after i ran it some stopped.
05-01-2014, 11:48 PM | #4 |
Newbie Join Date: Dec 2013 Location: scappoose
if axle halves are tightened different from side to side it caused some binding on one of my builds
SCX10 underdrive gear making clicking noise.... - Similar Threads | ||||
underdrive gear noise? | Gravebane525 | Axial SCX-10 | 6 | 09-22-2013 12:47 PM |
Clicking noise... | bur1196 | HPI Wheely King | 10 | 05-05-2011 07:23 PM |
Awfull clicking noise??? | Kamikaze | Tamiya TLT Crawlers | 20 | 08-29-2006 04:05 PM |
