03-26-2014, 04:02 PM | #1 |
Newbie Join Date: Mar 2014 Location: SD
| RC4WD King Shocks Size
Searched and couldn't find a straight answer. What do you guys recommend for a stock honcho? 90mm/100mm? 90mm is in stock, but 100mm is out of stock.. Any feedback is appreciated. |
03-26-2014, 04:08 PM | #2 |
Quarry Creeper Join Date: Mar 2009 Location: Central WA
| Re: RC4WD King Shocks Size
90mm. Will keep the stock ride height. Going to 100mm will increase travel, but at the added cost of an increased ride height and with that higher COG. You will be more prone to rollovers. You can get a lift kit such as the Delrin one Gearhead makes and use it as a lowering kit to retain stock height and run longer shocks. You would be able to keep stock ride height with the 100mm's using the lift kit, but the added benefit of more flex isn't always worth it. More flex = more body roll in off camber situations = rollover. Keep the links as close to parallel with the ground as possible and have just enough flex to fit one tire stood up underneath your flexed tire and you should be good to go!
03-26-2014, 05:36 PM | #3 | |
| Re: RC4WD King Shocks Size Quote:
I was thinking 90mm too, better then risking getting the 100mm and not liking it and to just play it safe with the 90mm | |
03-26-2014, 06:20 PM | #4 |
Rock Stacker Join Date: Sep 2011 Location: mcminnville
just because the shocks are longer, doesn't mean that it will automatically set up higher. I ran the losi 4" shock's on my old scx10 and left the adjustments all the way soft. it didn't set any higher than the stock shocks but it gave it more travel while crawling because the tire could drop down farther.
03-26-2014, 06:24 PM | #5 | |
RC4WD King Shocks Size - Similar Threads | ||||
G-Made Piggyback shocks vs. RC4WD King shocks | crwlnCreeper | Axial Wraith | 33 | 01-20-2016 09:48 AM |
rc4wd king sct shocks | desertmaxx | Non Crawler RC's | 2 | 04-27-2014 11:41 AM |
RC4WD King Shocks | thekdk604 | Axial SCX-10 | 2 | 11-12-2013 08:48 AM |
