04-08-2014, 02:05 PM | #1 |
Rock Crawler Join Date: Dec 2013 Location: Sacramento
| What length shocks do you run?
I'm curious what length shocks people are running to satisfy clearance, low COG, and articulation. Do you also run lift or droop? What's your magic setup? Sent from my SCH-I545 using Tapatalk |
04-08-2014, 05:24 PM | #2 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
| Re: What length shocks do you run?
100mm Losi comp shocks limited to 93mm mounted in Alpha Angle...30wt oil..1.8lb springs..custom modded pistons Stock ride height..stock body height...stock tire diameter Last edited by 6sharky9; 04-09-2014 at 04:17 PM. |
04-08-2014, 11:37 PM | #3 | |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
Rear Aluminum big bores limited internally to 85mm with Tmaxx red springs. Has a significant forward weight bias. I don't have much flex at all, but the minimal flex and stiff rear springs make a very predictable and stable crawler. Body is right down on the frame, running flat fenders to clear 4.75" tall Compass tires Also there is no such thing as a magic set up. 100 different people will tell you 100 different ways to set up a truck, but its up to you to find your ideal setup. Cheers! Last edited by gottorque; 04-08-2014 at 11:40 PM. | |
04-08-2014, 11:49 PM | #4 |
Quarry Creeper Join Date: Jan 2007 Location: Las Cruces, New Mexico
stock losi shocks with 1.8 springs. mounted on the inner holes on the top and moved to the bottom to the outside of the mount with a longer screw.
04-09-2014, 03:20 PM | #5 |
Pebble Pounder Join Date: Mar 2014 Location: Vancouver
Stock icon aluminum shocks, rear hole in front and middle on rear. Stock springs. 30wt oil. All on my fiances unlimited rubi kit version. Works great but need more weight up front. Going to swap the battery up front and electrics to the back
04-09-2014, 05:46 PM | #6 | |
| Re: What length shocks do you run? Quote:
I immediately went to a 100mm shock after stock thinking that it was all about how much articulation you can get. Now I'm thinking that mass amounts of articulation are really just for pictures and don't really help much on the trail. If anything I think it makes the truck loose/wobbly. I had purchased some VP SCX Limiting straps and noticed that they're only 3.25". Seems that this may be the "magic" length that you want to work toward! This afternoon I pulled the 100 mm shocks in favor of some AE V2 front shocks (3.25" eye to eye). The limiting straps fit perfect and now I think I'm back around the stock ride height. Still have a decent amount of articulation, but now side to side (pressing on one side of the truck) is much tighter. Not like a boat in in a big swell....if that makes any sense to you all! | |
04-09-2014, 06:01 PM | #7 |
RCC Addict Join Date: Oct 2012 Location: Norcal
103 mm Gmade piggies with fairly stiff springs up front, this rig is a pig! Love them!! Last edited by Norton; 04-09-2014 at 06:12 PM. |
04-09-2014, 11:25 PM | #8 |
While were at it, you have to put up better pics than your front yard. Throw that thing in some mud, It does not take that much to make it worthy. Hint on cleaning: While still wet, Simple green and compressed air. |
04-09-2014, 11:43 PM | #9 | |
I agree with testing in a comp...if all goes well ill be at the one coming up in PA Last edited by 6sharky9; 04-09-2014 at 11:47 PM. | |
04-10-2014, 12:21 AM | #10 |
I'm going to say what everybody is thinking, show us your rig doing anything other than your lawn or steps. Well, I think I saw you trying to climb a shale hill? Your modified rig will fail at comps. I will say though, all that matters is that your still happy with your rig.
04-10-2014, 12:35 AM | #11 | |
Ok..thanks..appreciate your opinion | |
04-10-2014, 12:38 AM | #12 |
Newbie Join Date: Jun 2011 Location: Savage
I have a honcho with 1.9 iroks. I run 90mm hot racing "scale" shocks. Fronts are tipped back with the stock shock mount and medium springs...back shocks are triangulated with a custom crossmember and soft springs. Works fantastic!! I love these hot racing shocks. Way smoother than stockers and look mostly scale. And less than $40 for a set f & r.
04-10-2014, 01:46 AM | #13 |
Newbie Join Date: Feb 2014 Location: Indiana
I run 93mm Gmade piggybacks. Still experimenting with setup so I have no preferred way to run my shocks... yet. I do kind of wish I had went with the 103mm shocks instead, is it just the rod that is longer or is the shock body longer as well?
04-10-2014, 07:20 AM | #14 |
Pebble Pounder Join Date: Oct 2005 Location: Noblesville , IN
I just switched from from Gmade piggyback 103s to pro line slash fronts 90mm with +5mm rod ends so 95mm on all 4 corners. Lower COG same amount of travel as the Gmade. Will see at the Iron Mountain G6 this weekend! Sent from my VS980 4G using Tapatalk |
04-10-2014, 07:30 AM | #15 |
Newbie Join Date: Jan 2014 Location: Canada
pretty good info on the thread, I was about to replace my stock scx10 shocks to get better flex and articulation. But seems like i will stay with my stocks for now.
04-10-2014, 08:47 AM | #16 | |
Ill take less flex and more stability over your alpha angle any day. | |
04-10-2014, 08:48 AM | #17 |
04-10-2014, 12:20 PM | #18 |
| Re: What length shocks do you run? |
04-10-2014, 05:17 PM | #19 | |
04-10-2014, 05:50 PM | #20 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
Proline scaler shocks with the small grey springs replaced with the stock short springs. 40 weight oil. Not a lot of flex, just enough to stay stable when I sidehill. Good foams also help with the way the suspension works, deuces wild are my foam of choice. |
What length shocks do you run? - Similar Threads | ||||
Length of big bore shocks | jebster | General Crawlers | 2 | 09-11-2013 11:27 AM |
What Length Shocks? | FruitaCrawler | General Crawlers | 1 | 11-22-2009 08:52 PM |
Length of axial shocks | d-fly | Axial AX-10 Scorpion | 0 | 04-15-2009 06:31 PM |
Whats the length of Hilift shocks? | F250 | 1.9 Scale Rigs | 0 | 10-20-2008 06:00 PM |
