04-11-2014, 05:48 AM | #1 |
Rock Stacker Join Date: Jun 2009 Location: charleston
| Upper Links on a G6 Kit?
Does anyone know if there is a full upper link replacement kit for the G6 kit? I just got the kit together and want to replace the junk upper plastic links.
04-11-2014, 06:52 AM | #2 |
Newbie Join Date: Mar 2014 Location: Hawthorne
| Re: Upper Links on a G6 Kit?
Many make their own links. I used push rods from my Revo and they worked perfect on my SCX10 rubicon, you can find them cheap in ebay too.
04-11-2014, 07:11 AM | #3 |
Quarry Creeper Join Date: Aug 2011 Location: United Kingdom
No link kit! Same lengths as the jeep or honcho front uppers! Check the 12.3" link kit instructions for the parts. You may want to use a 5mm longer post to tilt the pinion angle a little so the axle drive shaft is a little more online. ... |
04-11-2014, 11:51 AM | #4 |
RCC Addict Join Date: May 2008 Location: Southern,WV
| Re: Upper Links on a G6 Kit? Yes there is a kit too.....
04-11-2014, 11:51 AM | #5 |
| Re: Upper Links on a G6 Kit? R2J makes a kit. It's like $36.00. They're made out of stainless with revo rod ends. R2J is a vendor on here so you can find him pretty easy. |
04-11-2014, 05:28 PM | #6 |
Quarry Creeper Join Date: Nov 2013 Location: Erie
| Re: Upper Links on a G6 Kit? |
04-12-2014, 03:24 PM | #7 |
Quarry Creeper Join Date: Mar 2014 Location: san antonio
I'm a complete been to this so please pardon my lack of knowledge. What is the advantage of metal uppers as opposed to the plastic that comes with the kit? Sent from my iPhone |
04-12-2014, 03:50 PM | #8 | |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Re: Upper Links on a G6 Kit? Quote:
With solid upper links, your front axle will maintain its caster that you have adjusted it to, as well as saving your driveshaft joints and transferring the energy from the motor straight to the ring and pinion. Thus improving the performance and making it feel more planted. Last edited by Lentsnh2012; 04-12-2014 at 03:54 PM. | |
04-12-2014, 03:53 PM | #9 |
Appreciate the wisdom lentsnh2012. I'm in the process of buying/build the recon g6 kit and trying to get as many functional parts as possible to build a reliable rig. Sent from my iPhone |
04-12-2014, 03:57 PM | #10 |
| Re: Upper Links on a G6 Kit? R2J Kustoms, Vanquish Products and other vendors offer custom length links or ready to go link kits for all of the Axial line.
04-12-2014, 03:58 PM | #11 |
Do you know off hand the size for the uppers on the g6 kit? I haven't even purchased the kit yet so I don't have the instructions as reference. Sent from my iPhone |
04-12-2014, 04:12 PM | #12 | |
Once you find the length, I usually add a few millimeters to the length, so that, the pinion angle is angled up more to relieve a little more stress on the driveshafts and allow the lower links to slide over the obstacles instead of the driveshaft. | |
04-12-2014, 04:48 PM | #13 |
Thanks a bunch. I'll look around and figure it out so I can have parts on hand during my build. Sent from my iPhone |
04-13-2014, 04:25 PM | #14 |
Thanks for the info guys! I ended up making the links out of stainless steel tubing. They turned out great!!
04-13-2014, 04:28 PM | #15 |
04-13-2014, 07:48 PM | #16 |
I used 1/4 tubing witch you can use aluminum or stainless tubing. Then I used 8-32 allthread ran through the tubing and used traxxas rod ends. Very easy
04-13-2014, 07:53 PM | #17 |
Upper Links on a G6 Kit? - Similar Threads | ||||
Upper links and lower front links | TrademarkJeff | 2.2 Scale Rigs | 1 | 03-30-2010 11:03 AM |
KK upper links? | rockassassin | EnRoute Berg | 2 | 02-28-2009 10:50 PM |
