04-14-2014, 08:07 PM | #1 |
Pebble Pounder Join Date: Jul 2012 Location: SJ
| Custom links
I am making my own custom links for my axial scx10 and was going to do an allthread through a piece of 1/4" aluminum tube. Where is the best or cheapest place to get 1/4" aluminum tubbing? Thanks |
04-14-2014, 08:13 PM | #2 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Re: Custom links
Home Depot, Lowes, your local hobby store, Autozone....
04-14-2014, 08:20 PM | #3 |
Newbie Join Date: Mar 2014 Location: 781
Show us pics of the result and process Sent from my iPhone using Tapatalk |
04-14-2014, 08:25 PM | #4 |
| Re: Custom links |
04-14-2014, 08:38 PM | #5 | |
| Re: Custom links Quote:
Aluminum will gouge into the obstacle. A harder metal will be better such as, Stainless Steel. | |
04-14-2014, 08:51 PM | #6 |
Rock Stacker Join Date: Mar 2014 Location: Nothrwest
| Re: Custom links
I have always used brake line from the auto store. A 5 foot piece will give you plenty for top and bottom links as well as steering links. I have made links for racing clodbusters to crawlers and have always had good luck. And it is cheap material to work with. But I suppose you could go with stainless if you wanted to.
04-14-2014, 08:51 PM | #7 |
Newbie Join Date: Mar 2014 Location: paradise
I'm using 1/4 solid stainless steel and going to drill and tap for 4 mm revo ends good luck breaking these lol Sent from my HTC6600LVW using Tapatalk |
04-14-2014, 09:39 PM | #8 | |
What brake line do you use? steel? or stainless? No rust? How does it hold up? | |
04-14-2014, 09:58 PM | #9 |
Pebble Pounder Join Date: Feb 2014 Location: Tracy
I used brass tubing..slides pretty well ..not the strongest far as dents..but works fine. I'm probably gonna use solid stock 3/16 turned down then tapped 8/32 once these get pretty hammered. Sent from a whiskey downer beer pounder's shop |
04-14-2014, 10:51 PM | #10 |
| Re: Custom links
Just standard brake line. The stuff they carry now is coated in something.. If you look at my posting of my rubicon you can see the links I made. I don't run my trucks in water.. So I can't answer the rust question..
04-14-2014, 10:56 PM | #11 |
| Re: Custom links |
04-14-2014, 10:58 PM | #12 | |
Thanks | |
04-14-2014, 11:14 PM | #13 |
| Re: Custom links
The coating on it will scratch but as for dents.. I don't believe I have ever dented any links.. But I suppose it's all in how you drive or crash..lol.. But the line is cheap so just make a few spares and if anything happens just throw a new link in.. I keep a journal on my trucks and write the lengths down that I cut so if I ever need a replacement I can pull my notes out and make another. It is a lot stronger than the stock plastic links and I figure the truck would break the mounts way before a link goes.
04-14-2014, 11:21 PM | #14 | |
Cool thanks imma go with that brake line you got. What allthread size are you running on it? 8-32"? | |
04-14-2014, 11:30 PM | #15 |
| Re: Custom links
Yes 8-32 with Revo rod ends. I ran a tap through the rod end to make putting the ends on easier.
Custom links - Similar Threads | ||||
Will I need Custom Links? | WestTxRc | Losi Mini-Rock Crawler | 15 | 10-17-2011 01:19 PM |
