Stock scx10 Esc problem i have a stock scx10, i've had it for almost 12months now. i was using it the other day when i turned it off and raised the shell, when i plugged it back in and turned it back on my esc was flashing green non stop. i had no steering or throttle. what can i do or try to resolve the problem and continue scaling? |
Re: Stock scx10 Esc problem sounds like a reviver or radio problem. try rebinding your rx to your radio and try it again. |
Check the throttle trim. If it is not centered the ESC will not initiate the throttle. Does it still steer? That will tell you if its a tx/RX issue. |
Re: Stock scx10 Esc problem i had no steering or throttle. what can i do or try to resolve the problem and continue scaling? he already said he had no steering or throttle.. OP, have you checked the batteries in the transmitter? the transmitters can and do fail fairly often...some last a long time, some go out earlier |
