04-17-2014, 02:58 PM | #1 |
Newbie Join Date: Apr 2014 Location: Lowell
| Lift kit/driveshaft issue
I just installed a lifttkit in my scx 10. To accommodate larger tire.. On the test run I blew out the front drive shaft..any info on what type to buy-how to adjust axel angel would be great,.... Thanks in advance
04-17-2014, 03:36 PM | #2 |
Rock Crawler Join Date: Feb 2012 Location: Tennessee
| Re: Lift kit/driveshaft issue
Change the length of your suspension links to correct the angles. Depending on the height you raised it you may need to change you front axle steering components or it will steer like crap. Or a better way, lower it back down and cut the body. |
04-17-2014, 06:56 PM | #3 |
^ lengthen the upper links 3-4 mm and clock the front axle (rotate ^ forward) You may need increased caster Chubs and knuckles to do this effectively/properly. The king pin axis should angle rearward at its upper side. some positive caster should remain to be correct. if you drive slow (crawl) you could get away with zero caster. But you don't want to have negative caster. clocking the axle results in a host of other issues that will need be attended to... for proper correction. search here or google "clocking axle" for further information. * edited to reflect the proper spelling of caster Last edited by TacoCrawler; 04-20-2014 at 06:10 PM. |
04-19-2014, 08:51 AM | #4 |
Thanks guys!... Great info... I'll def try those ideas and let ya know how I make out... I'm new to crawlers/scalers but not he RC world... Wish I would have known it was a nightmare before I installed and trashed my truck. :-/
04-20-2014, 05:33 PM | #5 |
Pebble Pounder Join Date: May 2011 Location: The Wizzle, MA
Also, if you're googling, it's spelled "caster". "Castor" will just tell you about beans and stars.
04-20-2014, 06:08 PM | #6 |
dam I know that and still spell it incorrectly |
04-23-2014, 08:01 AM | #7 |
RCC Addict Join Date: May 2008 Location: Southern,WV
| Re: Lift kit/driveshaft issue |
Lift kit/driveshaft issue - Similar Threads | ||||
driveshaft issue | Exocaged | Axial AX-10 Scorpion | 3 | 11-12-2013 10:52 AM |
Ugc fastback ....driveshaft issue | day215 | Axial AX-10 Scorpion | 15 | 12-26-2010 01:09 PM |
Driveshaft rings issue | DrtRacr440 | Axial AX-10 Scorpion | 9 | 08-19-2009 05:20 PM |
Driveshaft issue | Mav-1981 | General Crawlers | 10 | 05-16-2009 08:59 PM |
