04-19-2014, 11:17 AM | #1 |
Newbie Join Date: Dec 2013 Location: Canada
| need some wheel hex help guys
picked up some Dick Cepek beadlocks for my honcho , the problem im having is I cant get the center cap on as the axels are too long.. im looking for a wider hex.. the stock honcho ones are about 5mm thick.. does anyone make a 8mm thick aluminum hex?? any help is appreciated.. links?? part numbers? thanks guys |
04-19-2014, 12:32 PM | #2 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: need some wheel hex help guys
Yeah...you can find the wheel hexes on ebay. I had the same problem with my wheels too.
04-19-2014, 03:11 PM | #3 |
Newbie Join Date: Jan 2010 Location: North Texas
I just used some plastic ones from taraxacum when I did my vp chubs and knuckles. I wanted to try the plastic ones before I bought the aluminum ones, but haven't found a reason to replace them yet. I believe they're around 8-10mm. I didn't measure. They work great and were cheap.
04-20-2014, 10:40 AM | #4 |
all I can seem to find is having to buy 2 sets of traxxas ones either the 3654 plastic or 6869 aluminum
04-20-2014, 11:50 AM | #5 |
why not just shorten the axles a bit...I presume you are talking about the threaded portion sticking out too far. I had the same issue with my axial universals that did this and I just ground down the ends a bit and it is fine now. I still have plenty of threads for the nut to hold on to...
04-20-2014, 05:04 PM | #6 |
just figured if something comes up down the road, ide rather have the thread.. and a little wider stance wouldn't hurt anything either |
need some wheel hex help guys - Similar Threads | ||||
Wheel Hex Help | jlsandkes | Axial XR10 | 6 | 10-18-2011 08:45 PM |
wheel hex? | toka100 | General Crawlers | 4 | 09-20-2011 10:56 PM |
Wheel hex | Onebdgti | Axial AX-10 Scorpion | 2 | 05-19-2011 01:11 PM |
Taking hex out of wheel without damaging wheel? | bi_eep | Newbie General | 8 | 03-06-2008 04:58 PM |
wheel hex | yukon635 | Newbie General | 4 | 07-01-2006 01:26 PM |
