Thread: Wraith axles installed into SCX10- Driveshaft help...PICS
Old 04-23-2014, 04:45 AM   #1
Default Wraith axles installed into SCX10- Driveshaft help...PICS
I just did the swap, runs great but the drive shafts are rubbing the upper links, even after I shaved them.
What Driveshaft would you recommend? I need a thinner one in diameter.
Thanks for any help.
1BAMFR is offline   Reply With Quote
Old 04-23-2014, 06:40 AM   #2
Default Re: Wraith axles installed into SCX10- Driveshaft help...PICS
high clearance 30degree upper links would help.
SwampDawg is offline   Reply With Quote
Old 04-23-2014, 07:08 AM   #3
Scale Detail Engineering
I made bent upper links for mine with Allthread.
But, it looks lime you could get away with flipping the trans.
johnnyh66 is offline   Reply With Quote
Old 04-23-2014, 07:39 AM   #4
Any links you would recommend?
Old 04-23-2014, 07:40 AM   #5
The trans/motor is switched already! I had to because the driveshaft angle was so bad it was barely spinning the axles.
Old 04-23-2014, 10:53 AM   #6
You need to flip your axles so the diff cover is on the other side
Sent from my SGH-I337M using Tapatalk
Mr.Xj420 is offline   Reply With Quote
Old 04-23-2014, 01:17 PM   #7
When I had it like yours it seemed the driveshaft angle was so much it was binding like crazy!
Old 04-23-2014, 02:09 PM   #8
stretching the wb would help with that
Old 04-23-2014, 02:22 PM   #9
This is how mine is and the drives hafts have been fine for well over a year. Mine has a 12.5" wheelbase though and yours looks shorter.
craddock35 is offline   Reply With Quote
Old 04-23-2014, 02:27 PM   #10
Its just over 13, i can measure it for you when I got home from work if you like
Old 04-23-2014, 02:41 PM   #11
What links can you recommend to stretch the rear back further? (length)
Old 04-23-2014, 02:43 PM   #12
Is your wheelbase about the same as a Wraith now?
I know my scx-10 is shorter than my Wraith
Old 04-23-2014, 02:55 PM   #13
I had it out on the rocks today, Drove great but like you guys stated...longer wheel base would be great and different upper links to eliminate rubbing.
Old 04-23-2014, 02:56 PM   #14
Then I swapped the tires out...they were too damn big!
These 2.2's are way better
Old 04-23-2014, 04:07 PM   #15
I will have more info for you tonight when I get home from work, your rig is looking awesome ....
Old 04-23-2014, 04:47 PM   #16
Thanks man! I appreciate your help.
Old 04-23-2014, 04:48 PM   #17
No prob I remember the s**ti went through building mine
Old 04-23-2014, 05:17 PM   #18
I made all my links so I just made them to the length I wanted and needed. I am not sure what you would need as far as buying them other than measure what you have and talk to somebody that makes the like VP or Chaotic Crawlers and tell them what you have and what you want.
Old 04-23-2014, 06:23 PM   #19
This is the way I've got my links, full flex both ways, no rubbing on driveshafts. Wb is 12.5
Mike Flea is offline   Reply With Quote
Old 04-23-2014, 07:02 PM   #20
That is pretty cool how the upper links are bolted to the outside of the chassis!
Wraith axles installed into SCX10- Driveshaft help...PICS - Similar Threads
scx10 before and after pics with wraith axles sawhead Axial SCX-10 1 11-25-2013 02:54 PM
Need width of scx10 axles with 650 SLW hubs and/or 750? Pondering wraith vs scx10. Desert Rc General Scale Talk 6 06-25-2012 05:28 PM
Servo/ESC installed [pics] fatwreck General Crawlers 3 03-01-2006 03:47 PM
I need some pics of an installed Pede tranny? painly Tamiya TLT Crawlers 8 11-26-2004 12:37 PM
