Thread: Jevne CMS Brick plate and VP CMS
Old 04-24-2014, 11:21 AM   #1
Default Jevne CMS Brick plate and VP CMS
Can anyone tell me if the Jevne Racing CMS Brick Plate will work with my VP CMS? I have the VP CMS that attaches the servo to the inside of the frame rail - the servo runs parallel with the frame rail.
By looking at the pictures, I'm not sure if the Jevne Brick Plate will work without major modifications to either the CMS servo bracket or the brick plate.
Thanks in advance for your help!
Sent from my modded TI-83 plus.
2-shot is offline   Reply With Quote
Old 04-24-2014, 11:52 AM   #2
Default Re: Jevne CMS Brick plate and VP CMS
If you get the Jevne CMS plate it should clear just fine. I'm about to put one on my Bronco with a Hand Bros CMS system.
Ty@Tekin is offline   Reply With Quote
Old 04-24-2014, 02:42 PM   #3
Thanks Ty! I do remember your reply to my PM regarding this.
On the Jevne Racing website, it says that they had to cut a notch out of the Hand Bros CMS bracket to get the CMS Brick plate to fit properly in the front.
Just wondering if the VP and the Hand Bros CMS's are similar???
I guess it's not a huge deal if I have to cut a notch out of the CMS bracket...
Old 04-24-2014, 04:00 PM   #4
It does fit. I recently purchased these and have them currently on my scx10.
urnot2brightru is offline   Reply With Quote
Old 04-24-2014, 04:13 PM   #5
Awesome!!! Did you have to modify anything to get the Jevne CMS Brick plate to work?
Old 04-24-2014, 05:01 PM   #6
No it doesn't. The VP CMS mounts in the front and the Hand Bros mounts along the side. If you try both you will have to cut out the front of the JR plate to go around the servo.
Here is the side view of the JR plate with the cms. I don't have my VP cms mounted yet but you can see how it goes up to the front of the truck.
Don't know how anyone would get that to work together.
juttsvw is offline   Reply With Quote
Old 04-24-2014, 05:06 PM   #7
Here is another top view after I had to cut down my plate. You can see the VP cms up front.
Here is a view from underneath
Old 04-24-2014, 05:26 PM   #8
I don't have the VP bumper mount CMS. I have the newer CMS that mounts along the side of the frame rail. The servo runs parallel with the frame. I don't have the CMS installed yet, so I grabbed a couple pics from VP's website.
Old 04-25-2014, 08:50 AM   #9
Yeah, that's the bumper mount, not chassis mount setup from VP. I have the bumper mount on my JK and the Jevne Brick plate, it's a lot taller.
I am going to have to notch the Hand Bros mount to get my JR plate all the way down in position, you're right on that one.
Old 04-25-2014, 09:17 PM   #10
Like I said, I have both and I didn't modify anything. It's tight, but it fits. I could take a pic if really needed.
Edit: I have the vp cms 3 link kit. Not the bumper mount cms.
Old 04-25-2014, 09:59 PM   #11
If you wouldn't mind taking a pic and posting it, I would like to see the Brick Plate with the VP CMS.
Old 04-26-2014, 07:26 PM   #12
Here you go. Yes it's dirty. was playing in the water/mud.
Jevne CMS Brick plate and VP CMS - Similar Threads
Jevne Racing Recon Brick SCX10 Battery Plate badd_maxx25 Axial SCX-10 19 03-29-2015 02:34 PM
