04-25-2014, 09:49 AM | #1 |
Rock Stacker Join Date: Oct 2012 Location: Mid Coast
| Trans question
A while back I picked up all the RR gears for my trans, and was just curious about something. I have the new wb8 shafts that use the through pin, but the Robinson one piece gear seems to just use a set screw. Will this cause me headaches when I install it, or should I just do it use a set screw and heat shrink over it? Just don't want to throw a shaft when I'm out running trails.
04-25-2014, 10:42 AM | #2 |
| Re: Trans question
Either drill the output for through pins or drill and tap the drive shaft yoke for a pair of 4mm set screws. A single 3mm set screw won't hold the driveline on for long.
04-25-2014, 11:09 AM | #3 |
Rock Stacker Join Date: May 2010 Location: Bluefield,WV
| Re: Trans question
When I built mine a put in the Robinson one piece. I cut the pins down and used a little lock-tight on them and have not had a problem with them yet. I'm also running a 13.5 Tekin brushless on 3s. Though if it ever starts to give me problems I might try drilling it out but it would not leave much material on either side of the output.
04-25-2014, 11:40 AM | #4 |
RCC Addict Join Date: May 2008 Location: Southern,WV
| Re: Trans question |
04-29-2014, 09:50 AM | #5 |
Quarry Creeper Join Date: Oct 2013 Location: Nanaimo
Just drill a small divot on the flat part of the output and use a short bolt head 3mm. Just carefull not to over tighten and snap it off.
04-29-2014, 11:39 AM | #6 | |
Pebble Pounder Join Date: Feb 2014 Location: Tracy
Used 4mm grub screws loc tited down....rig ran on 4S..geared for torque and never a single problem Sent from a whiskey downer beer pounder's shop | |
Trans question - Similar Threads | ||||
Trans question.. | Beej | Axial Wraith | 2 | 06-22-2013 06:19 AM |
Trans question?? | Kelly H | Axial Wraith | 2 | 05-03-2013 09:19 PM |
trans question | mugapug | Traxxas Crawlers | 3 | 02-02-2013 08:23 PM |
trans question | mac6986 | Newbie General | 2 | 06-18-2008 01:03 PM |
E-Trans Question | RCHunter | Traxxas Crawlers | 2 | 08-08-2005 03:01 PM |
