04-28-2014, 03:44 PM | #1 |
Newbie Join Date: Apr 2014 Location: WNY
| Another Rubicon Build...
Hey all, I've been lurking here for a while, picking up ideas and researching options for my latest build. This is my first crawler, everything previous having been on-road or monster truck setups. I was basically looking for something a little more low-key, with fewer headaches and carnage compared to my nitro vehicles. I settled on a Rubicon kit and built it up fairly standard, from a component perspective. I wanted to do something at least semi-scale, so I ran with the exterior details a little bit. Here's the list: Holmes BRXL Holmes 35T Expert 87/14 spur / pinion Futaba 3PM Castle 10A external BEC Castle Link Quick Connect Savox 0231MG servo Jevne Ultra battery mount Sealed project boxes front and rear RC4WD Stamped Steel 5-lug wheels w/ weights RC4WD Warn Winch Axial Simple LED light kit / buckets Krawler Konceptz handles / latches DS Pro snorkel Reign CB antenna Vanquish JK light bar mounts Gearhead Desert Torch waterproof light bar HeyOK remote light controller DIY door / hood hinges DIY expedition rack / ladder Lights are modular on separate connections so I can swap bodies in the future and vary my lighting. The light bar has a manual override switch on the front box - it's controlled from the transmitter with the other lights, but I can elect to shut it off if I don't need so much light. The rack is constructed from silver soldered brass tubing. It mounts via the original roll cage hard points for the roof (drilled out for heavier hardware). At any rate, it's nothing too unique, but I thought I'd share. I'm working on a second body at the moment - a Proline Rubicon Unlimited this time. The plan, at the moment anyways, is a monochromatic (top and flares) scheme in gun metal. Probably no rack or light bar. Last edited by THX_138; 08-09-2014 at 10:37 PM. Reason: Image size limit 800x600 or smaller |
04-28-2014, 04:10 PM | #2 |
RCC Addict Join Date: Aug 2005 Location: Pocatello
Nice! Subtle, clean build. The way I like them. Sent from my XT1080 using Tapatalk |
04-28-2014, 04:18 PM | #3 |
Quarry Creeper Join Date: Feb 2009 Location: Rocky Mountains
| Re: Another Rubicon Build...
That is an AMAZING rig! I love it. Just everything works so well. I've not been a huge fan of that body (especially when the top is off), but you've made it look like a million bucks. Congrats on a super build. Steve |
04-28-2014, 05:37 PM | #4 |
Pebble Pounder Join Date: Mar 2013 Location: near rochester ny
Very nice looking rig ! Love the white. Where in wny are u at? I'm near rochester.
04-28-2014, 06:57 PM | #5 |
Quarry Creeper Join Date: Nov 2013 Location: Erie
Love your roof rack with the ladder off the back. Great job Did you custom make it yourself?
04-28-2014, 07:11 PM | #6 |
Rock Stacker Join Date: Dec 2012 Location: rochester
Wow! That is extremely clean. Love the door handles and hinges,etc. Very cool!
04-29-2014, 01:05 AM | #7 |
Newbie Join Date: Aug 2011 Location: Kingman, Az
Wicked clean, love the little touches you did to pull it all together. Gives me ideas on my build, getting near the body stages now. (really should of photo and posted but oh well maybe ill retro post one when done.) |
04-29-2014, 10:13 AM | #8 |
Newbie Join Date: Aug 2012 Location: nj
do you just paint the door handles and latches with what type of paint ?
04-29-2014, 12:06 PM | #9 | |||
Thanks all for the comments. I'm pretty happy with how it turned out. It's not as scale as some of the setups I've seen on here, but I just wanted it to be a bit more complete than stock. Quote:
Afraid I only have a single photo from the construction process. This is pre-grinding and sanding (and pre-ladder). Finish is Rustoleum self-etching primer topped with gloss black. Quote:
The handles and latches appear to be an SLA material - they're from Krawler Konceptz. The hinges are .040 styrene sheet and .060 rod. All of them are finished with Rustoleum primer and satin black. | |||
04-29-2014, 08:25 PM | #10 |
Rock Crawler Join Date: Feb 2013 Location: Casper
Great build... Some r2j sliders would look great on that. Here's what they look like. The body slides into the groves. |
04-30-2014, 07:10 AM | #11 |
Your rims ... did you paint them ? I cant find them in Black ...
04-30-2014, 07:13 AM | #12 |
nevermind .. I was looking for them in a 2.2 size
04-30-2014, 10:10 AM | #13 |
Rock Stacker Join Date: Sep 2013 Location: Orlando
Nice Build. Love the look of the white on the Rubicon.
04-30-2014, 12:53 PM | #14 |
Newbie Join Date: Apr 2014 Location: Blah Vegas
What light bar are you using?
04-30-2014, 01:12 PM | #15 |
Newbie Join Date: Oct 2012 Location: aitkin
Great job! Love that roof rack. |
04-30-2014, 01:58 PM | #16 |
Thanks again guys! It's a Gearhead Desert Torch bar. Gear Head 1/10 Scale Desert Torch LED Light Bar - Waterproof |
04-30-2014, 06:40 PM | #17 |
Pebble Pounder Join Date: Jul 2007 Location: Reedsburg
Love the jeep I will be getting one it's soon as it gets here I like the white but mine is going to be green and black
05-01-2014, 01:08 AM | #18 |
Pebble Pounder Join Date: Mar 2014 Location: San Diego
Awesome Rubicon! I use the same wheels on my Rubicon. How did you get the black paint to look flat? Flat Paint? Brand of paint please. How did you get the rear windows tinted? Very nice. Thanks |
05-01-2014, 11:35 AM | #19 | |
| Re: Another Rubicon Build... Quote:
Both the black and white are Tamiya polycarbonate paint, sprayed on the outside. I wanted a matte finish to the whole body. It's backed on the inside with the same colors in the respective areas to reduce the visual impact of scratches. Everything is then backed with black to keep it looking uniform underneath. The window decals that Axial ships with the hardtop are tinted in the rear. However I've had great luck with Tamiya's translucent smoke for window tinting though. It's what I'm planning on using on the Proline body I'm doing now. | |
05-02-2014, 12:59 AM | #20 |
Thank you. |
Another Rubicon Build... - Similar Threads | ||||
Rubicon build | jdmitrswapped | Axial SCX-10 | 8 | 07-10-2013 12:45 AM |
4 dr Rubicon build-up | sgtsteve | 1.9 Scale Rigs | 9 | 02-13-2009 10:22 PM |
Rubicon Build | Ty@Tekin | 2.2 Scale Rigs | 89 | 02-10-2009 07:08 PM |
Another K2 Rubicon Build | bluonyx | 2.2 Scale Rigs | 5 | 04-24-2007 06:56 PM |
