05-17-2014, 10:24 AM | #1 |
Pebble Pounder Join Date: Jan 2013 Location: Raleigh, NC
| Homemade bumper mounts?
I've searched and just can't find anything good. What I am looking for is how people have built front and rear bumper mounts for homemade fabbed bumpers. Materials, design, etc would be great. I'm not interested in buying bumper mounts: I've made my own f&r tube bumpers and am struggling with the frame mounts. I've tried a few different things and not been happy with any, so I seek the collective's wisdom. |
05-17-2014, 11:46 AM | #2 |
Quarry Creeper Join Date: Nov 2007 Location: Orygun
| Re: Homemade bumper mounts?
You can use some 1/16" or 20ga sheet steel and make your own, OR use the factory mounts with round stock to mount like the Axial bumpers do...they'd slide in the holes and pin them in.
05-17-2014, 11:48 AM | #3 |
Quarry Creeper Join Date: Nov 2012 Location: Paxton
I always just make some plates that use factory frame holes and hold them on with 3mm hardware. Then weld my bumpers to those.
05-17-2014, 03:54 PM | #4 |
Good ideas. hotrodvw I am fussing with the idea of using the stock mount with a sleeve for the tube, and warren a piece of plate would be simple and look stock (which I like). Also curious about other ideas....
05-17-2014, 08:06 PM | #5 | |
| Re: Homemade bumper mounts? Quote:
Other than that, I'd bolt it up to the outside of the frame rails. | |
05-17-2014, 08:16 PM | #6 |
Pebble Pounder Join Date: Feb 2014 Location: Tracy
Get some key stock...I forgot what size but it will.slide right in frame rails...cut to length..drill and tap...or through bolt. I used some on a bumper build for a buddy for his scx..i put a cross bar in between for strength(axle mounted servo). Check clearances and flex before tacking it in.. Sent from a whiskey downer beer pounder's shop |
05-18-2014, 05:54 AM | #7 |
I have some oversized 8mm keystock which I think I'll use for the rear bumper, to try and even out the weight distribution a bit. It does slide right into the framerail c-channels.
Homemade bumper mounts? - Similar Threads | ||||
Homemade Outboard Shock Mounts | Nofriendstaco | Losi Mini-Rock Crawler | 35 | 04-21-2012 09:27 AM |
bumper mounts | oilylizard | Axial SCX-10 | 1 | 09-27-2009 08:35 AM |
homemade parts, motor mounts and upper link mounts | muddeprived | Tamiya Clod Buster | 5 | 04-15-2007 09:04 PM |
Homemade Motor Mounts | psychofreak | Tamiya Clod Buster | 22 | 02-22-2006 11:39 PM |
