05-22-2014, 09:01 PM | #1 |
Pebble Pounder Join Date: Apr 2013 Location: Central PA
| Front and rear axles turning at different rates?
I took my scx10 out to the state park this last weekend and noticed after a while that my front axle was turning slightly jittery, while the rear was turning nice and smooth. I thought maybe my driveshaft was overextended, but even when I push my front end up, it still jitters a little bit. I don't know if this is normal, as I haven't ever noticed it before.
05-22-2014, 09:06 PM | #2 |
| Re: Front and rear axles turning at different rates?
Are the joints in the front drive shaft in phase with each other?
05-22-2014, 09:13 PM | #3 |
I think so. I took it out, and ran it like that and had no problems with it crawling over anything. It's just odd. I should take the axle apart and check the diff, but I think it is the shafts being at too much of an angle, really. I want to get MIPs for it.
05-22-2014, 11:57 PM | #4 |
Quarry Creeper Join Date: Mar 2013 Location: Moscow Russia
Most likely bevel gears in front axle. I had it, common problem.
05-23-2014, 03:22 PM | #5 |
Rock Stacker Join Date: Jun 2012 Location: Santa Monica/Venice
Yeah sounds like a gear issue to me...
06-03-2014, 07:10 PM | #6 |
Rock Crawler Join Date: Aug 2012 Location: Port St Lucie
I had the same problem. It was my drive shaft. I installed some MIP's and problem solved.
Front and rear axles turning at different rates? - Similar Threads | ||||
front & rear axles | milenko_78 | Losi Micro-Rock Crawler | 1 | 10-10-2010 11:49 AM |
front and rear axles | tombstone | General Crawlers | 4 | 02-23-2006 01:49 AM |
