05-30-2014, 08:12 PM | #1 |
I wanna be Dave Join Date: Oct 2008 Location: Golden
| How to install the plastic Rigid Industries roof light bar for JK G6 & Deadbolt cages
Not sure if this has been mentioned before, but Axial was smart enough to make a Rigid Industries light bar that works for the G6/Deadbolt cage: Compared to the original: It's easy to see there's a much lower profile than the G6 light bar, and it has spots for more LEDs; the rigid bar uses 8 LEDs vs the stock 5. The C/R Edition SCX10 comes with these light bars as extras that are not much use to those with that vehicle: The 132mm bar is what fits the G6 and Deadbolt cages. (Second longest in the picture) So, what do you need to install these? Parts trees: AX31095A AX31095B AX31096 Hardware: AXA435 - M3x10mm self tapping screws (2) AXA013 - M2x6mm screws (3) AXA0424 - M2.6x10mm self tapping screws (4 - you already have these screws from the G6 or Deadbolt) Specifically the pieces highlighted here: Axial will probably have this whole kit available soon, since they have the part number AX31152 set aside for it: "Universal Rigid Light Bar Set" I got my parts from RPP salvage, but anyone with the C/R edition JK will have these parts just lying around in the box, so I would guess these will start showing up in the classifieds. These are easy to swap over from the bigger light bar. Remove the old light bar (save the two screws from each side that screw into the A-Pillar) then follow the exploded view from the C/R Edition Instruction Manual (Page 19). Notice that you have to use the new mount (part #4 on tree AX31095B) otherwise the light bar will not fit... I also had to drill out the mount for the M3 screw on this piece. Bonus: you will also be able to use the short light bar in front of the grill if you want to. (Just need a couple more screws and the other pieces from the parts trees above.) Hope this helps someone looking for a lower profile light bar. Anyone that does this, please feel free to post up a pic of your rig here. Any questions or comments, feel free to post them here as well. |
05-31-2014, 09:20 PM | #2 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
| Re: How to install the plastic Rigid Industries roof light bar for JK G6 & Deadbolt c
Thanks for the info Monkey racer as I will be doing this for my g 6.
06-03-2014, 08:51 AM | #3 |
Newbie Join Date: Feb 2014 Location: Portsmouth
What did you do about LED's? I can't find the same led light string as the one they use....
06-03-2014, 08:40 PM | #4 | |
| Re: How to install the plastic Rigid Industries roof light bar for JK G6 & Deadbolt c Quote:
I have another lightbar that needed LEDs so I ordered a bunch of them and the appropriate resistors. I will post pictures when I get that done. If you didn't want to do that , the other route would be to get a couple 5-LED strings and put 8 in the rigid bar, and the two extra in the bumper, or as rock lights, etc. (Or 4x 2-LED strings) | |
06-11-2014, 02:30 PM | #5 |
Quarry Creeper Join Date: Nov 2007 Location: Orygun
| Re: How to install the plastic Rigid Industries roof light bar for JK G6 & Deadbolt c |
06-11-2014, 05:36 PM | #6 | |
Nice! Although that's a different light bar than what is being discussed in this thread, that's another idea on how to mount them. | |
06-11-2014, 05:56 PM | #7 |
True, but it's another option. I did clean up where I cut the lights off. =)
How to install the plastic Rigid Industries roof light bar for JK G6 & Deadbolt cages - Similar Threads | ||||
Rigid industries Ligth bar into G6 light rack | Hotrodvw | Axial SCX-10 | 1 | 03-01-2014 06:52 PM |
Rigid industries LED light bar from VP | Mike McLeod | Axial SCX-10 | 3 | 12-27-2012 01:33 AM |
