06-02-2014, 06:37 PM | #1 |
Pebble Pounder Join Date: May 2014 Location: Escatawpa
| Offset wheels for Pitbull rockbeast
I just installed the Vanquish stage 1 kit which has the 8 degree knuckles. I am wanting a set of beadlock offset wheels to go with the 1.9 Pitbull Rockbeast I just ordered so I can have more clearance. Any suggestions? Sent from my iPhone using Tapatalk Last edited by Derek108; 06-02-2014 at 06:41 PM. |
06-02-2014, 09:10 PM | #2 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
| Re: Offset wheels for Pitbull rockbeast
Wider wheel spacers. Vanquish should make some wider wheel hexes for the scx10 so that we don't have our tires rubbing the inside of our tires. Hint hint.
06-02-2014, 09:13 PM | #3 |
Yeah. What are some good beadlock wheels to get for the pitbull rockbeast ? Sent from my iPhone using Tapatalk |
06-02-2014, 09:15 PM | #4 |
I have a set of traxxas wheel hub tall off sets on them now that give me the clearance Sent from my iPhone using Tapatalk |
06-03-2014, 05:26 AM | #5 |
Rock Crawler Join Date: Nov 2010 Location: the 'burgh'
If you use the Traxxas wide hex (I suggest the blue aluminum over the gray plastic) you can get away with a .475 hub. I prefer the .600 on my rigs but that's just me. VP has some nice wheels as you know, and Locked up has some nice wheels that are SLW hub compatable and are a little less costly. |
06-03-2014, 12:42 PM | #6 |
Rock Crawler Join Date: Jul 2013 Location: Manchester
I have a set of aluminum mayhem wheels for sale .... Huge offset .. Hex mount so you don't need hubs Sent from my iPhone using Tapatalk |
06-03-2014, 12:49 PM | #7 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
VP Wheels and Hubs is one way to fix it. I had to put Integy 7mm wide hexes on my JK to get my RC4WD DC7's to clear my VP chub/knuckle setup with 1.9 Rock Beasts. You can run .475 hubs on VP wheels with plenty of clearance on the stock SCX10 hexes. |
06-04-2014, 09:29 PM | #8 |
Yeah I talked to VP today and decided to go with the 600 offset and knuckle weights Sent from my iPhone using Tapatalk |
Offset wheels for Pitbull rockbeast - Similar Threads | ||||
Vanquish SSZ Series Scale Wheels featuring PitBull RockBeast XOR Tires and C.I. Foams | jeeper_05 | Tires and Wheels | 65 | 10-03-2011 04:36 PM |
