06-03-2014, 11:00 AM | #1 |
Say hello to my dactylion Join Date: Jun 2004 Location: On the Boat to Whore Island
| PinchFlat's Honcho to Deadbolt Conversion
So one of our local clubs (801RCC) does these KICK ASS Ultra4 endurance type events each month and with all these awesome Axial rigs out & coming out there has been discussion of running an additional class at the 801RCC Ultra4 events. Currently they are running Ultra class (basically 2.2 all balls rigs) and a Trail class (a mostly open 1.9 class). So now they will be running a Stock class. Sounds like a blast to me. Here is the basic rules & regs for the stock class: T-Money:"The idea behind stock class is to create a class that is very inexpensive to get into and very inexpensive to maintain. Along with creating a class that every vehicle has very similar performance. So it should make it more of a "drivers" class. -Stock:- Any RTR or production vehicle running a 2.2" or 1.9" rim. Vehicles in this class can not have any performance enhancing upgrades. This class will be limited to 6000mah 2s batteries and brushed motors, 27t or higher. Servos will be limited to 160oz or less. Driver can swap and change equipment to other components of equal performance. Example: A driver of an RTR Honcho may opt for aluminum steering and lower links because other production SCX10 "kits" come stock with these components. Due to not being able to tech certain internal components, trans and axle gears may be swapped for HD options. No overdrive setups. No additional weight to the vehicle or wheels. Gearing changes are legal." Sounds fun right? Well I don't have anything close to being out of the box stock but my good old Honcho Bismarck is close-ish. Now time for a conversion from semi-modified Honcho to bone stock Deadbolt. I got hold of a take-off Deadbolt body and a trip to the LHS for a poison spider front bumper and a light kit and a few other miscellaneous parts to get started. Still need: -Swap out frame rails for OEM un-braised on metal sliders & bumpers -Replace front axial housing with new one with posts, so I can mount a servo on the axle like the stock set-up -Add OEM sliders -OEM Axial rims -2c Battery packs -Find the OEM RTR electronics from the Honcho-hope they are still in working order -Create a Reign RC Grill for the Deadbolt body? Time to strip down Bismarck of all its upgrades and Honcho body. |
06-03-2014, 11:16 AM | #2 |
RCC Addict Join Date: Jun 2013 Location: Port Saint Lucie, Florida
| Re: PinchFlat's Honcho to Deadbolt Conversion
Nice, i like the "axial stock" class
06-03-2014, 11:18 AM | #3 |
RCC Addict Join Date: May 2008 Location: Southern,WV
We did something like that for awhile but ours was "stock" stock. You could only use parts that came on one of the scx10 models. RTR or kits. No upgrades at all. It was a blast...
06-03-2014, 10:19 PM | #4 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
Where I run they are gunna do stock class also I'm thinking of running a rtr green honcho. I'd have to return it to stock though. Sounds like fun.
06-05-2014, 10:33 AM | #5 |
So I have stripped all the non-OEM upgraded parts off Bismarck and returned it back to stock SCX10. - I swapped out the old braised on frame rails with metal sliders & bumpers for new OEM SCX10 rails - Added The Poison Spider front bumper - Added OEM Sliders - Mounted Light bar on Deadbolt body to match Green SCX10 Deadbolt body - Found the OEM RTR electronics (minus servo) from the Honcho-they are still in working order - Found some Axial beadlocks in my parts bin (gotta strip of the stick-on weight to return to stock) - Created and mounted a Reign RC Grill for the Deadbolt body (pics to come-gotta download from phone) Still need to: -Replace front axial housing with new one with posts, so I can mount a servo on the axle like the stock set-up -Mount up body -Shocks need a rebuild -Install Electronics -Find a stock servo (160oz or less) -Buy 2c Battery packs Last edited by PinchFlat; 06-05-2014 at 10:46 AM. |
06-05-2014, 11:43 AM | #6 | |
Quarry Creeper Join Date: Sep 2005 Location: Sandy, UT
Awesome Matt! Great to see support for this class! Quote:
"Upgrades" are allowed to RTR's so they meet the specs of the kits, but that's it. It's awesome that you can buy a $300 Deadbolt SCX-10 and if you can drive, you can be competitive in this class. | |
06-05-2014, 07:05 PM | #7 |
RCC Addict Join Date: Dec 2004 Location: Behind the wheel of an Axial R/C
Nice start, Pinch!! We'll have to get together for a trail run with new rigs soon |
06-05-2014, 09:30 PM | #8 |
How does the orange body line up with the mounting points. Are you going to run honcho length links? So that you've got the 98 fronts 106 rear links.
06-06-2014, 11:22 AM | #9 | |
| Re: PinchFlat's Honcho to Deadbolt Conversion Quote:
Yeah I am running stock honcho length links. | |
06-06-2014, 11:38 AM | #10 |
Might be able to use the JK style mounts in the rear - they have a bit of offset. I didn't try it, but it looked awfully close. Nothing doing in the front though, they are pretty far off. (Covered the old holes with vinyl wrap as well) Curious how that lines up with Honcho links. I started with a Dingo, and lengthened the rear about 5mm or so. Seems to fit good. |
06-06-2014, 01:10 PM | #11 |
Watching this thread. I've been thinking of using a Dolt body in place of the Dingo, just for tire clearance and a different look.
06-06-2014, 01:52 PM | #12 |
Friends don't let friends drive stock! Does the SCX Deadbolt use the same body with different mounts or same mounts with different holes? |
06-07-2014, 01:04 AM | #13 |
| Re: PinchFlat's Honcho to Deadbolt Conversion |
06-07-2014, 02:46 AM | #14 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
looking forward to seeing this new grill - And running one saying I just picked up the scx10 deadbolt
06-09-2014, 11:37 AM | #15 |
| Re: PinchFlat's Honcho to Deadbolt Conversion Still working on the design but check it out. I left part the the stock sticker showing through the grill holes.
06-09-2014, 01:53 PM | #16 |
Quarry Creeper Join Date: Feb 2009 Location: Rocky Mountains
Wow PinchFlat! That looks fantastic! Can't wait until these are available. Steve |
06-09-2014, 03:19 PM | #17 | |
Rock Crawler Join Date: Dec 2013 Location: Sacramento
06-09-2014, 03:24 PM | #18 | |
Very clever...must steal Quote:
06-09-2014, 03:26 PM | #19 |
06-09-2014, 03:38 PM | #20 |
PinchFlat's Honcho to Deadbolt Conversion - Similar Threads | ||||
Honcho to Beast Xj Conversion | donnielovett | Axial SCX-10 | 23 | 04-25-2014 09:34 AM |
Trying to decidle between honcho, wraith and deadbolt | Coonburger | Newbie General | 12 | 12-15-2013 08:17 PM |
Dingo to Honcho Conversion | jeeping33 | Axial SCX-10 | 4 | 04-18-2013 12:46 PM |
SCX-10 CF100 to honcho conversion | norbyx | Axial SCX-10 | 3 | 08-26-2010 09:24 AM |
Honcho leaf spring conversion | crawlerax | General Scale Talk | 1 | 08-20-2010 01:38 PM |
