06-13-2014, 06:12 AM | #1 |
Pebble Pounder Join Date: Apr 2012 Location: Katy Tx, from Riverside Cali
| Wierd suspension issues. (Video inside) I need help! FB09E9CE-E152-4ACA-AF84-244425D78B82_zpsuayuh7o6.mp4 Video by nickprorokovic | Photobucket Not sure if these links will work but hopefully you guys can see the videos |
06-13-2014, 06:14 AM | #2 |
| Re: Wierd suspension issues. (Video inside) I need help!
I'm sorry for the horrible video quality
06-13-2014, 07:14 AM | #3 |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
It looks to me that your upper links are too long. The suspension can't articulate in its intended range of motion. Essentially, when you push your axle up, you are binding on the triangle you create with your upper links. This is one time I wish I paid more attention in geometry class. I would try to relocate / shorten the uppers. OR relocate your shocks higher up. Do the axles move when the uppers are disconnected? I assume yes. 4 Links are meant to be more horizontal. The steep angle, reduces the effectiveness and obviously creates binding issues. |
06-13-2014, 08:18 AM | #4 | |
| Re: Wierd suspension issues. (Video inside) I need help! Quote:
06-13-2014, 08:23 AM | #5 |
I built a 6x6 from scratch. Took me some trial and error. Lots of error...
06-13-2014, 09:15 AM | #6 |
| Re: Wierd suspension issues. (Video inside) I need help! |
06-13-2014, 09:31 AM | #7 |
Quarry Creeper Join Date: Mar 2010 Location: SF East Bay
The upper links are too long, and mounted too high. You have essentially triangulated-out any vertical motion out of the suspension with your current setup. The three holes between where you currently have your upper links mounted on the chassis and the lower link mounts are the stock upper link mount locations--best to try those spots first with the appropriate length links. |
06-13-2014, 10:03 AM | #8 | |
I assume you are doing a monster truck build? What I would do is use the AX chassis for your link geometry, and the SCX chassis as the upper shock mounts. Don't try to combine the two. Even with using the AX chassis for your link geometry, it looks like you are asking for too much height out of your setup...those lower link and drive shaft angles are pretty steep. Good luck, and I'd like to see this once you get it worked out. | |
06-13-2014, 10:10 AM | #9 |
RCC Addict Join Date: Jul 2012 Location: Oreganastan
Why are you combining the scorpion chassis with the scx10? I have a scorpion based sporty. This is how mine are in the rear. I also am working on a 6 x 6 based on a scx10 chassis & I cannot see an advantage. KOM is right, the uppers are connected way high. Ahhh CHUD Monster truck, I guess I could see that. Last edited by Dostradamas; 06-13-2014 at 10:13 AM. |
06-13-2014, 10:40 AM | #10 |
06-13-2014, 02:11 PM | #11 | |
Ill post a mini build thread here soon. Quote: | |
06-13-2014, 02:13 PM | #12 |
Rock Crawler Join Date: Mar 2014 Location: Union City, CA
I agree. Shorten the top links and mount them lower.
06-13-2014, 02:30 PM | #13 |
First of all the axle should not roll like that. Second, the there is far too much vertical link separation between the upps and lowers at the chassis end. The uppers being too long shouldn't be much of a factor unless the driveshaft is at a bad angle. Speaking of driveshafts, make sure the collapsed length is short enough to compensate for the WB change during suspension cycle. To me, I bet that's actally what is preventing the suspension from compressing as it's probably bottomed out. |
06-13-2014, 04:37 PM | #14 | |
06-13-2014, 05:03 PM | #15 |
The axle rotation is not because of the lower shock mounting position. The uppers are holding solid, not rising. SCX10 shocks are mounted as you have yours in the vid. I still say move the upper mount down & shorten it until you get the pinion angle you want & it should cycle fine. Try it without the shocks & you can feel more of whats happening. |
06-14-2014, 08:03 AM | #16 |
06-14-2014, 03:21 PM | #17 |
Pebble Pounder Join Date: Aug 2013 Location: near jax
from the 1:1 world uppers should be 70% of the lower length and the separation at the frame should be half of what it is at the axle.
Wierd suspension issues. (Video inside) I need help! - Similar Threads | ||||
Front suspension issues | rawalker666 | Vaterra Twin Hammers | 6 | 05-04-2014 05:48 AM |
Suspension issues | jplynch90 | Axial SCX-10 | 14 | 01-19-2010 07:53 AM |
Suspension clearance issues | theslowguy | Axial AX-10 Scorpion | 4 | 12-28-2008 12:49 AM |
Suspension issues - need expert advice! | maccasvanquish | 1.9 Scale Rigs | 15 | 03-20-2008 10:26 AM |
Inside Project Crushed Video s | The_Green_Mennie | Videos! | 2 | 02-27-2007 06:17 PM |
