06-14-2014, 11:05 PM | #1 |
Rock Stacker Join Date: Dec 2011 Location: Ft mohave
| First upgrade
I just bought a scx10 jk and was wondering if there is any thing that I need to upgrade right away?
06-14-2014, 11:24 PM | #2 |
Quarry Creeper Join Date: Jul 2013 Location: Maple Ridge B.C. Canada
| Re: First upgrade
Whatever you manage to break first.
06-15-2014, 03:58 AM | #3 |
Pebble Pounder Join Date: May 2014 Location: fernandina beach
| Re: First upgrade
I think getting some weight down low on your axles makes for a more enjoyable driving experience. The FI spool from Locked Up RC is a really solid piece of steel and easy to install. Beef Tubes will also add weight and strength, just ream out the outer bearing truss in your axle housings with a 7/16 drill bit and lay em in place; you may have to use a round file until the halves press back together.
06-15-2014, 08:50 AM | #4 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
| Re: First upgrade |
06-15-2014, 09:42 AM | #5 |
| Re: First upgrade
And don't forget the coarse thread screws on the knuckles, and C's need to be replaced with machine screws.
06-15-2014, 09:41 PM | #6 |
| Re: First upgrade You nailed it. And don't forget the rear lockouts. That is absolutely the only thing that I feel MUST be done to any scx-10 right out of the box before I would ever even drive it.
06-15-2014, 10:36 PM | #7 |
Moderator Join Date: Jan 2004 Location: chicago
yep. definitely change the chub and knuckle screws.
06-16-2014, 09:40 AM | #8 |
Newbie Join Date: Jun 2014 Location: Southern AZ
I found nothing really needs to be upgraded until it breaks, but the first thing I did was aluminum suspension and steering links, definitely helped overall Sent from my iPhone using Tapatalk |
06-20-2014, 11:08 PM | #9 |
Pebble Pounder Join Date: Oct 2010 Location: Boulder, CO
Weight in the front wheels helps a lot, as does sticky compound tires if you like to rock crawl. It all depends on your goals and the type of driving you do. You can upgrade for performance, scale appearance, or durability. You picked a great truck, they do great right out of the box. I agree with the comment to just see what breaks.
First upgrade - Similar Threads | ||||
best upgrade for ax 10 | remday | Axial AX-10 Scorpion | 17 | 09-19-2013 04:33 PM |
Next Upgrade | joshjflores | Newbie General | 5 | 10-05-2010 09:04 PM |
First Upgrade | campboy | Axial SCX-10 | 5 | 09-11-2010 06:05 PM |
You only get one upgrade!! | RickM | Losi Mini-Rock Crawler | 28 | 06-11-2010 10:51 PM |
the best upgrade | Lavio86 | Newbie General | 29 | 03-19-2010 12:55 PM |
