Thread: Got used SCX10, what maintenance
Old 06-20-2014, 02:19 AM   #1
Default Got used SCX10, what maintenance
Hi guys,
I just bought an used SCX10 Honcho, it is upgraded as follows:
- True Bead Lock Wheels (internally weighted)
- 4 TomaHawk RC4WD Wheels.
- Aluminium Lower Links
- Servo Location Kit (RC4WD)
- RC4WD Metal Side Rails
- Metal Steering Linkage Links.
I will receive it by next week, what general maintenance is required? am planning to grease it, clean it. Is there other things I need to take care of?
Thanks,
questionare is offline   Reply With Quote
Old 06-20-2014, 05:54 AM   #2
Default Re: Got used SCX10, what maintenance
You should really strip it down to nothing, clean, inspect, re-lube, then re-assemble. Just so you know what the condition of everything is. I found some cool goodies that the original owner didn't tell me about with a recent scx10 trade I just got.
Johnnysplits is offline   Reply With Quote
Old 06-20-2014, 08:18 AM   #3
Thanks a lot, is there a manual for assembly/dissassembly, I already order the Axial Honcho manual.
This is my first SCX10, and I want to learn as much as I can about such crawler.
Thanks again,
Old 06-20-2014, 09:23 AM   #4
Thanks a lot for the feedback. I just purchased the Axial Honcho Instructional Manual, would it be enough to show me how to strip it down, and re-assemble it again? this is my first SCX10
Thanks,
Old 06-20-2014, 09:28 AM   #5
Like said above, strip it down and check/replace all the bearings, check ring and pinions, transmission gears, re-grease and re-assemble. There's not too much to them!
Ty@Tekin is offline   Reply With Quote
Old 06-20-2014, 12:14 PM   #6
if it is operable... and you want to do so immediately.
sooo... at the very least... be sure to check all the external screws
to be sure they are still tight.
loosing a screw on something vital...
can ruin your day !
But yeah... unless you know what the original owner
has done as far as maintenance...
prolly smart to tear it down and rebuild the whole deal.
the instruction manual should offer that insight.
one note...
apply some blue locktite to screws that thread into metal.
well if you have any of that.
Another tip if doing a rebuild...
replace the cheesy looking wood screws...
for 3mm machined screws.
They fit slightly tighter... and hold stronger.
TacoCrawler is offline   Reply With Quote
Old 06-20-2014, 01:20 PM   #7
can ruin your day !
one note...
Thanks a lot for the valuable feedback, I will tear it down, and replace any torn object, grease, re-assemble it again.
Thanks,
Old 06-20-2014, 04:31 PM   #8
That's one of the best tips right there!!! And that's exactly what comes with these r/c's...f'king wood screws!!
Old 06-20-2014, 05:17 PM   #9
Thanks for the contribution. What is the part number of the wood screws, am asking since am using the parts reference manual to figure out their location.
Thanks again,
Old 06-20-2014, 05:39 PM   #10
Natedog's Avatar
can ruin your day !
one note...
Agreed except there are a few places (the cage and a few others) where the self-tapping screws (wood screws as yall are incorrectly calling them) actually work better imo. And with all screws, they work best when they are carefully re-threaded into the existing self-tapped threads in the plastic, rather than just jammed into the hole and screwed in. Careful removal and reinstallation of all screws regardless of thread type will make the parts they are screwed into last much longer and hold tighter.
Old 06-21-2014, 08:51 AM   #11
Thanks again,
Buy this...http://www.rpphobby.com/product_p/rczaxi002.htm
I'm on my 5th build using these screws. Love them.
Old 06-21-2014, 10:50 AM   #12
Buy this...RC Screwz Stainless Steel Screw Kit Axial SCX-10
I will be going to get one, I have seen valuable feedback on such kit.
Is there a bearing kit that is recommended?
Thanks,
Old 06-21-2014, 02:15 PM   #13
I've had good luck with the cheap Avid bearings. They have a nifty feature to look up bearing kits by application on their site.
They are cheap enough that you may as well replace all the bearings on the truck as cheap insurance.
It would also be a good idea to pick up some 5x7x.1 and 8x12x.1 and 10x12x.1 shims to take out the excessive play in the transmission top shaft, the transmission output shaft, and the axles ring and pinion. This excessive slop is created by Axials somewhat loose tolerances, and then increases very slightly after enough abuse.
meatmonkey is offline   Reply With Quote
Old 06-21-2014, 10:18 PM   #14
Now that you are getting a manual, it won't be hard to disassemble and check all parts for serviceable wear. I would (like been discussed earlier) replace the machined 3 mm screws in everything that has tapered screws. Most importantly ball joint screws. I took a brand new rtr scx 10 out of the box a few years ago that had a ball joint screw missing loose in the box. Disassemble and check the axles and transmission bearings. I use Mobil 1 grease ( like you would put in a grease gun). If who ever had it and was hard on it it may need some bearings. I take my trucks apart every six months. The trans bearings last, but axle bearing you are replacing approx.half of them. I run mine pretty hard. Take the shocks apart and relube them . Switch the springs to soft for the front and super soft for the rear , for the duel spring rates. Check electronics wiring for fraying and replace as needed. Use lipo battery's. When you need a servo, go overkill. Get a super high torque high dollar one when needed. When you upgrade go for higher quality. Above all have fun. Welcome to the addition!!!!
im gunna crawl is offline   Reply With Quote
Old 07-02-2014, 01:56 PM   #15
I'm found the bearings on avidrc.com, no problem. But I can't find the shims. Did you get them from the same place?
sjc115 is offline   Reply With Quote
Old 07-02-2014, 02:01 PM   #16
If you want to start reading the manual now you can download it at http://docs.axialracing.com/instruct...Honcho_RTR.pdf
DynoXG is offline   Reply With Quote
Old 07-02-2014, 03:16 PM   #17
Thanks, I already started on it, very nice and well detailed manual
Old 07-02-2014, 03:17 PM   #18
2nd this, where we can find the shims
Old 07-02-2014, 03:21 PM   #19
I have it on my phone ready for when I need it on the field.
Old 07-02-2014, 06:00 PM   #20
x2, helps out in a pinch...
twb4525 is offline   Reply With Quote
Got used SCX10, what maintenance - Similar Threads
maintenance issue ?? rc dreemer Axial AX10 2nd-gen 21 08-26-2012 05:06 PM
maintenance? Hardline Axial AX-10 Scorpion 8 10-21-2011 10:21 PM
Maintenance buysomerice Newbie General 1 07-31-2010 11:36 PM
maintenance ped453 1.9 Scale Rigs 4 10-09-2009 07:44 PM
maintenance QuicherKryan Newbie General 6 04-28-2009 09:19 AM
