06-27-2014, 10:14 AM | #1 |
Quarry Creeper Join Date: Jun 2014 Location: Grand Haven, MI
| To vent or not to vent
Hey dudes. I am still very new to the scaler/crawler scene. I am going to be building my SCX G6 kit in the next week or so. I have read many threads regarding venting of tires. I am looking for tips for my particular setup and usage. Here is what I have going: I will have Gmade SR02 Steel Beadlocks on the truck. For now I am rocking the stock foams and stock trepadors. The truck will likely have an addtional pound or so added (plus the steel beadlocks) I will be running an AE2 ESC and the axial 27T on a 2s lipo. I will be doing mostly wooded area trail driving, but will also do some rocks and some wet areas. I plan on waterproofing my electrics to get this thing into some serious action if the need arises. I am thinking that I want to vent the tires in between the lugs, just 2 holes per tire. I have a leather punch and will likely do the smallest holes I can to try to preserve my scale looks that I am striving for. Am I barking up the right tree here? Does anything seem off about my conclusion? Thanks. |
06-27-2014, 10:47 AM | #2 |
| Re: To vent or not to vent
I will only vent a tire/wheel combo if the bead will not seal properly. a quality bead lock should seal without issue. Venting allows dirt, mud and water to infiltrate inside the tire and often the dirt inside the tire's interior, can grind on the foam inserts, damaging them. If one chooses to vent... I would recommend venting the tire on the outer diameter surface (tread) This way the debris inside the tire would have better opportunity to escape. |
06-27-2014, 10:48 AM | #3 |
Stock foams will not like water. My vote is run sealed, you loose a small amount of tire flex but you save the foams. I have ran standard beadlock s with a screw in the vent hole so I can equalize tire pressure on cold days. |
06-27-2014, 11:06 AM | #4 |
I run vented, though the rim or tire. Removes the air pressure equation from the mix completely and gives me very a very consistant feel all year. I don't run in water too much though, so take it for what you will. I do get the foams wet on occasion, but not bad enough that they've ever degraded or anything.
06-27-2014, 11:16 AM | #5 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
Vent and stay away from the water or be prepared to replace foams every so often. They wear out anyways.
06-27-2014, 11:17 AM | #6 |
I vent... could care less about the foams.
06-27-2014, 11:33 AM | #7 |
Vent the tires. I look into crawler innovations foams. They will help make the tire perform better and if you choose single stage foam they water resistant.
06-27-2014, 11:52 AM | #8 |
| Re: To vent or not to vent |
06-27-2014, 01:57 PM | #9 |
Quarry Creeper Join Date: Jan 2009 Location: Victoira,BC
just buy new foams everynow and again or don't. mine have been dead since i got my dingo a year ago. tire grips like no other
06-27-2014, 02:35 PM | #10 |
Rock Stacker Join Date: Jul 2013 Location: Northern 801
Crawler Inovations, nuff said Probably Sent Sitting On The Toilet... |
To vent or not to vent - Similar Threads | ||||
SandPaws in snow, sand, and water. Tape? Vent or no vent? | fizzx | Tires and Wheels | 3 | 01-05-2014 01:18 AM |
Vent HBs or vent the rims or both? | boisetrucker | Tires and Wheels | 10 | 12-27-2009 05:58 PM |
Poll: To vent, or not to vent... that is the question... | Katon | Newbie General | 20 | 12-23-2009 10:29 AM |
New Tires... To vent, or not to vent??? | sportpak | Newbie General | 27 | 05-08-2008 01:13 PM |
