07-01-2014, 05:11 PM | #1 |
Newbie Join Date: Jun 2014 Location: USA
| SCX10 Honcho 4 links upgrade
Hi... I got a used SCX10 Honcho; which was upgraded to aluminum lower links (Front, Rear), both rear & front lower links (the upgraded ones) are the same length (91mmx6mm). Reading over Axial web site, this should be done for dingo not honcho, is that right? and if I want to upgrade to 4 links, what length should I use for both front & rear (lower & upper). Thanks, Last edited by questionare; 07-01-2014 at 06:53 PM. |
07-03-2014, 04:47 AM | #2 |
Quarry Creeper Join Date: Dec 2009 Location: Strafford, NH
| Re: SCX10 Honcho 4 links upgrade
My front lowers are 98mm, rear lowers are 106mm, and rear uppers are 98mm.
07-03-2014, 06:15 AM | #3 |
| Re: SCX10 Honcho 4 links upgrade |
07-03-2014, 06:42 AM | #4 |
RCC Addict Join Date: Feb 2012 Location: Ca.
I don't know about most, I have 3 SCX-10's and have gone four link up front. Maybe you're looking at rigs that are CMS equipped? I had trouble with the single leg of the Y pulling out so I changed them all.
07-03-2014, 07:18 AM | #5 |
Rock Stacker Join Date: Feb 2011 Location: North of the border.
There is a lot of slop in the 3 link, so swapping out for the four link gets rid of the axel rotation that happens every time you start or stop. It's a wise upgrade! Sent from my iPhone using Tapatalk |
07-03-2014, 08:18 AM | #6 |
Rock Stacker Join Date: Sep 2013 Location: Orlando
I just changed the front over on my SCX10 to 4 link. Like ilg said, it took out a lot of slop up front. Wish it wouldn't have taken me so long to change it over...
07-03-2014, 08:28 AM | #7 |
Rock Stacker Join Date: Jul 2012 Location: Spijkenisse, Netherlands
I also have a question regarding links, I currently have a SCX10 Dingo (short wheelbase) but want to switch the front stock plastic y-link to some upgraded aluminium ones, but the most I see are for the honcho etc. (long wheelbase). Are only the rear links different in length or also the front links between the SCX10 short and long wheelbase? |
07-03-2014, 08:48 AM | #8 | |
| Re: SCX10 Honcho 4 links upgrade Quote:
07-03-2014, 05:55 PM | #9 |
Thanks all for the contribution... I have been watching videos over Youtube, and found one that gives links length for both Dingo & Honcho; as follows: Honch & Dingo (Front lengths are common for both)
Honcho (Back lengths):
07-04-2014, 05:06 AM | #10 |
07-04-2014, 02:42 PM | #11 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
Well, it depends on the wheelbase you want. Now of course you could do a short wheel base which is the dingo or the longer wheelbase is the honcho, but those axial links are ok although vanquish makes the best things..just saying.
07-05-2014, 09:13 PM | #12 |
Rock Crawler Join Date: Sep 2013 Location: New Orleans
On my second SCX10 now, this thread has gotten me interested in converting to four link up front on at least one of them to see how I like it. Both are short (Dingo) WB rigs. What would I need to convert the front upper Y to individual links? I take it the servo plate will need to be replaced and just an upper truss? New STRC Aluminum Adjustable 4 Link Plate SCX10 AX10 Gun STA30485GM | eBay The slop that you guys talk about with the three link has become quite annoying at times. |
07-06-2014, 04:51 AM | #13 |
You can use the Axial one that comes on parts tree AX80043
07-06-2014, 06:15 AM | #14 |
07-07-2014, 02:59 PM | #15 |
Newbie Join Date: Jun 2014 Location: Southern AZ
I have that strc plate and links and I like it, much more than the 3 link which, as discussed, has it's problems Sent from my iPhone using Tapatalk |
07-07-2014, 03:21 PM | #16 |
| Re: SCX10 Honcho 4 links upgrade Good deal, just trying to find out what I need to order before I start this project. So far looks like I'm going with Level3 RC center link mount and shim the servo plate if need be.
SCX10 Honcho 4 links upgrade - Similar Threads | ||||
Honcho Upgrade - Links and Shocks | XS NOIZ | Axial SCX-10 | 0 | 10-09-2013 12:10 PM |
SCX10 Honcho Vanquish upgrade question | igz | Axial SCX-10 | 10 | 08-20-2013 07:38 PM |
Axial SCX10 TR Aluminum Links Upgrade Set | remydegreat | Axial SCX-10 | 1 | 06-15-2011 11:11 PM |
SCX10 TR Aluminum Links Upgrade Set | Matt.k | Axial SCX-10 | 19 | 08-01-2010 08:15 PM |
Axial SCX10 TR Aluminum Links Upgrade Set (290mm) | Chief Brody | Axial SCX-10 | 10 | 07-31-2010 07:21 AM |
