07-02-2014, 08:16 AM | #1 |
Newbie Join Date: Mar 2013 Location: Apollo Beach
| Front Driveshaft Comes Off
Hi Guys, I'm running the stock drive shafts on my jeep and just can't seem to keep the front shaft from loosening and falling off. Any tips? I'm willing to upgrade if someone can point me to a good alternative. Thanks for any help you can provide. |
07-02-2014, 09:54 AM | #2 |
RCC Addict Join Date: Feb 2012 Location: UK
| Re: Front Driveshaft Comes Off
Need some thread lock. A little on the thread of the pin will secure it.
07-02-2014, 10:08 AM | #3 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
Blue LocTite on driveshafts, pinion, diff locker hardware, etc..
07-02-2014, 10:48 AM | #4 |
^ what they said... but I'll add... blue Loctite any screws turning into metal threads. but don't ignore the screws turning into plastic thread either. components under operational stresses can also work themselves loose. minimal use of CA glue for the plastic threads helps keep the screws secure. or... do a simple maintenance program and check them for looseness. |
07-02-2014, 11:09 AM | #5 |
Good point. Remove self tappers. Add proper screws...Stainless if possible.
07-02-2014, 11:09 AM | #6 |
Quarry Creeper Join Date: Jun 2006 Location: L-Town
Correct the blue lock tight is the way to go, don't use red by any means its turns into a bad day and $$. metal drive shafts do help like taco said but they seem to like to bind up if not taking care of
07-02-2014, 06:31 PM | #7 |
RCC Addict Join Date: Dec 2007 Location: Moncton, NB, Canada
Make sure the set screw isn't rounded off, or you might not be getting full torque on it when tightening. If it's rounded off and you're able to get it out, put a new one in. If not, then good luck |
07-02-2014, 06:42 PM | #8 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
Also check the flathead screw that holds on the WB8 CV to the plastic male/female slip joint.
Front Driveshaft Comes Off - Similar Threads | ||||
Front Driveshaft Binding | snakeman | Kyosho Crawlers | 6 | 12-04-2015 01:19 AM |
Venom Creeper Safari Front Driveshaft issues | xxROELKEYxx | Venom Creeper | 24 | 02-05-2012 07:33 AM |
put brushless in honco..now front driveshaft throws off everyime. | Kentuckcrawlers | Axial SCX-10 | 7 | 09-30-2010 10:48 AM |
front driveshaft wont stay on | zigster | Axial AX-10 Scorpion | 9 | 02-08-2009 05:21 PM |
BB-51 front driveshaft angle | JasonInAugusta | General Scale Talk | 33 | 03-12-2007 05:52 PM |
