07-15-2014, 09:52 AM | #1 |
Newbie Join Date: Jun 2014 Location: Southern AZ
| Scx10 battery relocation
Just thought I would share how I moved my battery onto the chassis. Definitely not the best way but it was easy and cheap. Definitely helped couldn't quite do this before Sorry the picture are bad (from my phone) I can probably get better ones if anyone wants more detail. Also any advice on improvement is fine I know this is the least professional way to move the battery. Sent from my iPhone using Tapatalk Last edited by sixty2; 07-15-2014 at 09:54 AM. |
07-15-2014, 10:07 AM | #2 |
Quarry Creeper Join Date: Jan 2009 Location: Pacific Northwest
| Re: Scx10 battery relocation
A cool solution. I wanted to move mine as well and I ended up buying a flat plate front steering servo mount. I do not use it for the servo, keeping that on the front axle. Instead I bought a 3c lipo that fits nicely in between the front shock towers. This allowed me to remove the high mounted stock battery location. I too noticed a difference much like you show in your photo. Its amazing how lowing the C of G and or mass centralization can do so much for these rigs! I think its cool you figured out an inexpensive way to do it!
07-15-2014, 10:21 AM | #3 |
Ya all I bought were some aluminum spacers for where the battery mounts to the chassis Sent from my iPhone using Tapatalk |
07-15-2014, 10:32 AM | #4 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
On my JK RTR I moved the battery on the frame rails and they're zip-tied to the front shock towers. On my honcho, I used the dremel and trimmed down the battery holder spacers to that the battery will sit much lower and the servo does not rub the battery plate. On my falken build right now, I planned on moving the battery up front like the stock honcho location so then I'll have room for all of my light wires to reach the receiver without an issue.
07-18-2014, 09:06 PM | #5 | |
Newbie Join Date: Jul 2014 Location: Warrington
| Re: Scx10 battery relocation Quote:
07-18-2014, 09:39 PM | #6 |
| Scx10 battery relocation Right here I have a long screw going through the a hole on the bottom of the receiver box into that hole on the chassis brace where the battery used to be mounted. The long black plastic spacer was also used there. Where the battery plate mounts there is about 10mm on each side of random spacers I had lying around. Then there are plastic servo mounts. If you really want me to I could pull up all the part numbers tomorrow. Sorry I'm sorta in a hurry right now. Sent from my iPhone using Tapatalk |
Scx10 battery relocation - Similar Threads | ||||
SCX10 battery relocation | VI™ | Axial SCX-10 | 4 | 06-09-2014 02:00 PM |
Battery relocation | some87 | Axial SCX-10 | 14 | 04-12-2014 10:50 AM |
battery relocation | rachad6 | Tamiya CR-01 | 13 | 01-15-2010 01:27 AM |
