STRC rear lockouts fitment issue Hey guys. I know STRC stuff is questionable at times, with now being one of those times. :lmao: I put the rear lockouts on my G6 and there is a good 1/4 inch of play in the rear axle output shafts. Am I missing something here? Looking inside the STRC lockouts, it almost looks like they will accept a bigger bearing further in. Any ideas here? |
Re: STRC rear lockouts fitment issue Quote:
I use strc rear lockouts and dont see how it would be possible for you to have any play. Could you be more specific, maybe some pics? (I am using Strc axles but not sure how that would make a difference.) |
Re: STRC rear lockouts fitment issue wait.. where do you have your bearing? It is on the axle right behind where the hole for the pin is so it actually sits just inside the outer (narrow) end of the lock out right? |
Re: STRC rear lockouts fitment issue There is a gap between where the bearing sits and the end of the lockout. This allows the shaft to move in and out. I ended up finding 2 nylon washers the same diameter as the bearing and put them in between the bearing and the end of the lockout. This actually worked really well, but I don't feel I should have to dig through my hardware to make something like that work. I poked around and found a couple of other people with the same issue. |
Most axles could use shimming here and there. It's normal - bearings, shafts, gears all wear or have separate tolerances. Get a shaft with tolerances to the far left and bearing to the far right along with not perfect lockouts - wiggle wiggle. |
Re: STRC rear lockouts fitment issue That's weird cause I didn't have issue's mounting STRC lockouts on my jeep Unlimited. Maybe they were cut wrong from the factory, that's all I can think of but I'd doubt that cause STRC quality isn't that bad. |
Re: STRC rear lockouts fitment issue i just installed some strc lockouts and have the same 1/4" of play. too late to find a fix tonight. going to tackle it in the morning. |
Re: STRC rear lockouts fitment issue Having the same issue myself, anyone figure out why? |
Re: STRC rear lockouts fitment issue Where do you shim? Having this issue myself, cost me and end link already. |
I would post pics but I sold that rig long ago. |
Re: STRC rear lockouts fitment issue Covered in the yeti section, cut a shim from old axle and insert in between the shafts.... 3.5 to 4mm works well HANG UP AND DRIVE ! |
Re: STRC rear lockouts fitment issue Yup, sounds normal, I have a bit of play in one of my Vanquish lockouts, not that much tho. Shim that mofo |
Re: STRC rear lockouts fitment issue I just did rear lockouts and found the same problem. I went back to the shop and the guys gave me some mini washers to soak up the wiggle. They said its normal but doesn't change performance. wiggle-wiggle-wiggle gone.... |
