07-16-2014, 08:42 PM | #1 |
Rock Crawler Join Date: Jan 2012 Location: Hudsonville, MI
| Mounting LED's in lexan head light buckets - SCX10 JK kit
I have a question about installing LED's in the dome shaped head light and parking light buckets that come in the SCX10 JK kit. I'm referring to the clear lexan buckets that get attached to the inside of the body. I know you drill / ream a hole in the center of the dome, on both head light and parking light buckets. What is the best way to attach the LED to the dome shaped buckets? Should I just use some Shoe Goo and glue them in? Should I get some of the LED holders and go that route? I like the idea of using LED holders mounted into the light buckets, but not sure if they will be too bulky. Any help or input would be greatly appreciated! |
07-16-2014, 08:59 PM | #2 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
| Re: Mounting LED's in lexan head light buckets - SCX10 JK kit
Try using either a good tape or sho goo may work although it might leave a huge mess everywhere so that's up to you haha.
07-16-2014, 09:05 PM | #3 |
anyone tried using a hot glue gun ? or would the the heat from the glue melt/warp the lexan buckets ? |
07-16-2014, 09:18 PM | #4 |
| Re: Mounting LED's in lexan head light buckets - SCX10 JK kit Depending on the thickness of the body I couldn't see it warping it. I guess this would work although don't put to much hot glue on there as it will look a little cheesy lol.
07-16-2014, 09:32 PM | #5 |
I'm gonna make a Radio Smack trip tomorrow. I'll take a look at some LED holders. If I can find some that won't look too funky, I may get a couple and try them. If not, I'll get out the Shoe Goo and go to town!!! Shoe Goo isn't bad to work with. Just gotta use really small amounts, especially for something like that. You definitely can't get crazy with it!!! |
07-16-2014, 09:36 PM | #6 |
| Re: Mounting LED's in lexan head light buckets - SCX10 JK kit |
07-16-2014, 09:40 PM | #7 |
Rock Crawler Join Date: Jul 2009 Location: Victoria Australia
I drill the hole so the LED is a tight fit and push them in, nothing else needed.
Mounting LED's in lexan head light buckets - SCX10 JK kit - Similar Threads | ||||
Light kit t attach LEDs to lexan buckets | mszymanski25 | Electronics | 7 | 05-15-2013 02:06 PM |
