07-19-2014, 12:51 PM | #1 |
Quarry Creeper Join Date: Jun 2014 Location: Grand Haven, MI
| Anybody use these Hot Racing driveshafts?
Hey guys. These look to be like a good fit for my G6. I really like the looks of these, and they are 2mm off from the lengths I need. Anybody try these? Hot Racing Axial SCX10 Steel Main Center Drive Shafts SSCX37V | eBay Anything else in this price range? I know many say to run MIP but that doesn't fit the budget at the moment. |
07-20-2014, 06:19 AM | #2 |
Quarry Creeper Join Date: Mar 2009 Location: martins ferry
Why doesn't mip fit the budget a set of shafts for the ax10 are the same price you are looking at there, that is what I am running work fine for me they just don't come with the long pin that goes clear through the output and pinion shafts but you can replace the grub screws later. The pins I used were from traxxas emaxx shafts I believe. http://www.ebay.com/itm/360982075894 Sent from my iPad using my finger |
07-20-2014, 08:48 PM | #3 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
| Re: Anybody use these Hot Racing driveshafts?
Use MIPS.
07-20-2014, 10:07 PM | #4 | |
| Re: Anybody use these Hot Racing driveshafts? Quote:
07-21-2014, 12:30 PM | #5 |
They will I'm using the same ones on my Rubicon worked fine with the 12.3 wheelbase and I just shortened it to 12 which is the same as the g6. The only difference between the ax 10 and the scx's as far as I can tell is the length but the ax 10 ones are long enough. The only thing that I can say is I swapped out the grub screws for a longer one from traxxas emaxx shafts so it goes through the hole on the pinion and tranny outputs. Sent from my SM-G900V using Tapatalk |
07-21-2014, 12:33 PM | #6 | |
07-21-2014, 12:37 PM | #7 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
Don't get china junk (hot racing), get MIPS or get nothing
07-21-2014, 01:02 PM | #8 |
| Re: Anybody use these Hot Racing driveshafts? |
Anybody use these Hot Racing driveshafts? - Similar Threads | ||||
Hot Racing Links are hot mess!! | Sethmetal | Axial Wraith | 53 | 04-12-2013 12:27 PM |
3 Racing or MIP Center Driveshafts | Paul97 | Losi Mini-Rock Crawler | 7 | 11-27-2009 11:57 PM |
Hot racing driveshafts | Ben Holloway | Losi Mini-Rock Crawler | 1 | 01-11-2009 01:48 PM |
