07-19-2014, 11:31 PM | #1 |
I joined the Band! Join Date: Jul 2014 Location: Alabama
| Axial Hi-Clearance Knuckles
Anyone know of a tutorial on these things I've got them installed but I can't seem to figure out how to run my steering linkage now. This is my first SCX10 so yes I'm a newb at this. Thanks for the help. Allen |
07-20-2014, 12:25 AM | #2 |
| Re: Axial Hi-Clearance Knuckles
CMS or axle mounted servo ? I cannot comprehend the mechanical difficulty so... Let me google that for you > " Images " if reading is too much effort > " Videos " if pictars bring no joy a search on this forum Last edited by TacoCrawler; 07-20-2014 at 12:38 AM. |
07-20-2014, 01:24 AM | #3 | |
| Re: Axial Hi-Clearance Knuckles Quote:
07-20-2014, 01:44 AM | #4 | |
07-20-2014, 01:46 AM | #5 | |
Thanks for the response. I'm still using the axial aluminum steering up grade that comes with the G6 kit. I guess I will need to upgrade to a bent style steering linkage? Thanks again | |
07-20-2014, 09:54 AM | #6 | |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
There is a box where you can choose the design of the linkage (it's under "Available Options") Just click on "Axial high steer knuckles" | |
07-20-2014, 10:38 AM | #7 | |
07-20-2014, 02:02 PM | #8 |
Make your own links. You can make custom bends if needed, make a few mistakes and have still spent less cash than buying any prefabbed set...
07-20-2014, 02:30 PM | #9 | |
obviously you're offended... because you don't. Most everything you might ask here... has been asked and answered. if you take the time to search and read. If you don't wish to... that's on you so maybe post in the newbie general folder where you would be removed from all criticism. Don't blame me for your shortcomings but so that you will be happy... I will refrain from commenting in your future threads. | |
07-20-2014, 04:59 PM | #10 |
Newbie Join Date: Feb 2014 Location: Craig
I had to run the short drag link to the bottom of the left knuckle. Then I had to run the long tie rod top to top behind the servo horn. It was toe in at first but two of the spacers from the upgrade kit made the tires toe out just slightly. I ended up breaking the rod end and made my own from 8/32 all thread and a small tube I found at the lhs. Just had this same issue about a week ago so I hope my input helps.
07-20-2014, 07:11 PM | #11 | |
Thank you from refraining in the future, if you had done so in the first place I wouldn't be wasting my time typing this to you now. | |
07-20-2014, 07:15 PM | #12 |
Thanks, for the great info everyone. It's definitely helped! I think I've got it figured out.
Axial Hi-Clearance Knuckles - Similar Threads | ||||
Axial Hi-clearance knuckles | Garry | Axial AX-10 Scorpion | 16 | 12-28-2010 11:49 PM |
