07-22-2014, 12:59 AM | #1 |
Newbie Join Date: Jun 2014 Location: USA
| Dual parallel 2s lipos on AS-E2
Hi guys, I am planning to run dual 2s 2200MAH lipos (in parallel) on my SCX10. It has the stock AS-E2 ESC. Would this risk the ESC, or it can handle doubling the MAH? Thanks in advance |
07-22-2014, 02:21 AM | #2 |
In parallel it will be fine....in series not so fine...but yes...parallel..i had mine set up that way for a long time. Its the same as a single 4400 mah lipo... |
07-22-2014, 07:36 AM | #3 |
Quarry Creeper Join Date: Jun 2014 Location: Grand Haven, MI
| Re: Dual parallel 2s lipos on AS-E2
ESCs can handle any capacity you desire. It's voltage you need to be concerned about. In your case you are still set up for 7.4 so you will have no issues there.
07-22-2014, 08:10 AM | #4 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
Will work fine, it's a good old school trick. I used to do it back in the day with 1500 mah nicads and the old Tamiya Clodbuster to get longer run times. (yes I am carbon dating myself...lol) |
07-22-2014, 10:06 AM | #5 |
you'll be fine. I run dual 3s LiPo's wired parallel but I use a BEC with that higher voltage. It's probably a good idea to charge each battery individually using the balance method each and every charge. * Your thread would be better placed in the Electronics Folder Last edited by TacoCrawler; 07-22-2014 at 10:10 AM. |
07-22-2014, 11:49 AM | #6 |
Thanks a lot guys, valuable comprehensive feedback What average run time would this setup give me? Am running stock motor with stock gearing Thanks Last edited by questionare; 07-22-2014 at 11:53 AM. |
07-22-2014, 12:04 PM | #7 |
Rock Crawler Join Date: May 2012 Location: Columbus
i run that on 3s an gives me about 45min to hour on hard playing
07-22-2014, 02:07 PM | #8 |
^ that's about right. but gear it lower and you can stretch it to an hour + maybe it would also be dependent on how many winds your stk. mtr. has. a 27 turn/wind mtr will usually demand more energy then say a 55 T/W mtr. would. so gearing and mtr. selection can be tuned towards performance or for max. battery capacity. and it all depends on what you want. I'm into the 3s LiPo's for their added torque top speed (maybe 5mph 4me) is useless for a crawler. JMO Wheel speed may be helpful in some circumstances... but too much and any scale resemblance is lost. So again... tuning your rig to what your wants and needs are... is completely up to you |
07-22-2014, 07:13 PM | #9 | |
| Re: Dual parallel 2s lipos on AS-E2 Quote:
I currently run 27T on the stock gearing, however, I already order 20T & 55T; just to see the difference. I somehow felt that 27T is fast, however, I do suspect that the 55T will be too slow. I will try, and maybe 35T would be the future suitable motor. Thanks again, | |
07-22-2014, 07:37 PM | #10 | |
I run 3s mmp an 13.5 novak for wheel speed proly to much for crawling but more the better | |
Dual parallel 2s lipos on AS-E2 - Similar Threads | ||||
Two 3S lipos in parallel | Exocaged | Electronics | 16 | 07-09-2013 12:04 PM |
Dual lipos in series, my plan, comments? | shelljeep | Electronics | 4 | 12-01-2010 10:48 PM |
two 3 cell lipos in parallel ? | rc_pimp | Electronics | 7 | 07-24-2010 02:45 PM |
Dual Lipos = 8 plugs | Creep | Electronics | 10 | 07-14-2006 11:29 PM |
