07-23-2014, 06:23 AM | #1 |
Quarry Creeper Join Date: Mar 2014 Location: Athens, Al
| axle mod question
Im still fared new to the scx style axles and dont know much on the mods to them. I did we a post with a pic of an axle with burly tubes and wraith knuckles and c's is the burly tube the mod that allows this or is it somethin else. What are the pros and cons of runnin those knuckles and cs.
07-23-2014, 11:50 AM | #2 |
RCC Addict Join Date: Jan 2009 Location: Bend
| Re: axle mod question
All the answers you seek can be found in these two threads, or by searching... How to do the narrow XR10 mod to Axial axles Steering Improvements In the process of doing the narrow XR mod myself. Using brass 1/8" X 3" MIP fittings from the hardware store to make my own beef tubes. Most buy them from the various vendors here making them ready to go. I personally like building things, so figured I'd give them a shot on my own. Another couple threads by HPIguy and MRCrackhead describing the process of doing the "long XR mod" for a 2.2 sportsman build, using the same supplies and a spare Wraith housing for the chub splines. Same axle and tech, different rig and purpose... Cheap SOB Crawler Build Ugly Betty Last edited by 89redranger; 07-23-2014 at 11:55 AM. |
07-23-2014, 01:29 PM | #3 |
Newbie Join Date: Jan 2007 Location: Washington DC
Does anyone know what length axle shafts work with the wide tubes (CTBM) mounted in a rear axle? I've searched and scanned many threads only to see some say long side XR(117mm) and other say short side XR shafts(110mm). The XR shafts are out of stock online and I don't really want buy 2 packages anyway. Maybe a custom axle vendor could help me out with the correct pair that I need. I don't have variable offset wheels so I don't want to make up the difference that way. Again, WIDE tubes and SCX lockouts = 1xx mm length axles. Thanks much! |
07-23-2014, 01:49 PM | #4 |
I've pondered the same about rear shafts and lockouts. I'm currently doing the narrow version of the XR mod, but could appreciate a matched f/r track width without using wideners or SLW's. Never found a definitive answer, so I'm moving forward with just the front for now.
07-23-2014, 02:46 PM | #5 | |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
| Re: axle mod question Quote:
2x XR10 long side or a custom shaft from a vendor. | |
axle mod question - Similar Threads | ||||
Front axle mod | michael | Axial XR10 | 5 | 09-10-2011 09:27 PM |
Axle tube mod? | Manfjourde | Tamiya Clod Buster | 4 | 07-02-2011 10:12 AM |
XC Axle mod | Nitro_Geezer_UK | Tamiya XC/CC01 | 7 | 09-17-2009 01:10 PM |
Axle Mod | BUGGYBOY | Tamiya Clod Buster | 2 | 12-04-2007 01:49 PM |
