07-23-2014, 08:11 AM | #1 |
Quarry Creeper Join Date: Jan 2013 Location: Long Island, NY
| Wheel spacers
I'm looking into getting some wheel spacers. I think they would help in making the truck more stable, plus the truck would look better with them I think. What do you recommend for a stock scx10? I was looking at these: Mini 12mm Wheel Widener (4) |
07-23-2014, 08:24 AM | #2 |
RCC Addict Join Date: Oct 2012 Location: Norcal
| Re: Wheel spacers
I would recommend these: Junfac Wheel Widener (Offset: +13mm) If you look around, you can find them. |
07-23-2014, 10:35 AM | #3 |
Newbie Join Date: Jun 2014 Location: salt lake city
| Re: Wheel spacers
all depends how wide you want to go. the rc4wd mini wideners are ok, ive got a set. but on scx10 axles its almost like running wraith axles at that point. if you just need like 1-2 mm then use different hex's maybe. junfacs are good just a bit wider then the ones you linked.
07-23-2014, 12:24 PM | #4 | |
In the band for now. Join Date: Sep 2012 Location: roselle
| Re: Wheel spacers Quote:
07-23-2014, 01:47 PM | #5 |
| Re: Wheel spacers
Where can I get them?
07-23-2014, 01:48 PM | #6 |
| Re: Wheel spacers
I see AMain has the ones I posted.
07-23-2014, 04:58 PM | #7 |
Quarry Creeper Join Date: Jun 2012 Location: pomona
| Re: Wheel spacers
I have the Junfac and are very happy with them. I would suggest putting a drop of non- permanent Loc-Tight on the long bolts.
07-23-2014, 05:10 PM | #8 |
Rock Crawler Join Date: Feb 2014 Location: ?
| Re: Wheel spacers
Junfac +13mm is my advice. Got mine here: Gmade 2 2 inches Duralumin Wheel Widner Offset 13mm 1 10 RC Car Off Road J51032 | eBay |
07-23-2014, 05:34 PM | #9 |
| Re: Wheel spacers
Are GMade a knock off? I'd prefer something in the USA. Got a link to that? |
07-23-2014, 05:43 PM | #10 |
| Re: Wheel spacers
Gmade and Junfac are the same company.
07-23-2014, 06:42 PM | #11 |
| Re: Wheel spacers |
07-23-2014, 06:46 PM | #12 |
Pebble Pounder Join Date: Nov 2012 Location: illinois, rockford
| Re: Wheel spacers
I run the junfac spacers myself with 1.9 wheels and 1.9 bfg krawlers. IMO with wideners you need taller tires as it will actually be more difficult to go over obstacles. that's just what I've experienced.
07-23-2014, 07:04 PM | #13 |
| Re: Wheel spacers |
07-26-2014, 09:24 PM | #14 |
| Re: Wheel spacers
Just got my Junfac spacers. I'm looking at them and I'm not sure how to install them. Does anyone have a picture of instructions or a picture of them mounted? Thanks. |
07-26-2014, 10:41 PM | #15 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
| Re: Wheel spacers |
07-27-2014, 07:08 AM | #16 |
| Re: Wheel spacers
Thanks, just got them on!
07-27-2014, 07:13 AM | #17 |
Pebble Pounder Join Date: Feb 2014 Location: NH
| Re: Wheel spacers
For a more subtle effect, Traxxas makes some 8mm wide hexes. Set of 4 runs about $7 (two of item #3654). |
07-27-2014, 08:22 AM | #18 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
| Re: Wheel spacers I run the 8mm wide hexes on a few rigs as well, Pro-Line also makes them ( part# 6097-00 ). The stock hexes are about 4.5mm so by adding 8mm hexes it only gives you about a 7mm wider width on your rig. This does work pretty good on a stock rig though, also the wider hexes are good if you ever plan to run VP steering knuckles, since they tend to have clearance issues with some wheels.
07-27-2014, 11:19 AM | #19 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
| Re: Wheel spacers
Who makes 8 mm wide hexes?
07-27-2014, 01:04 PM | #20 |
| Re: Wheel spacers |
Wheel spacers - Similar Threads | ||||
Wheel spacers | 0lllllll0 | 1.9 Scale Rigs | 4 | 12-05-2010 08:18 PM |
Wheel Spacers? | ttown180 | Tires and Wheels | 0 | 10-27-2009 12:02 PM |
wheel spacers??? | newth | Traxxas Crawlers | 11 | 12-17-2004 11:05 AM |
