Thread: ~TSS~ SCXHR Chassis Build & Info: Performance Chassis Upgrade
Old 03-03-2016, 09:08 PM   #61
Default Re: ~TSS~ SCXHR Chassis Build & Info: Performance Chassis Upgrade
Interested in a chassis myself. Have any on the way?
rckjeep is offline   Reply With Quote
Old 03-05-2016, 01:03 AM   #62
I recieved my al frame rails and the skid today, very fast shipping!
The weight for the al frame rails is 3.8 ounces, very light. Once everything was bolted together the chassis feels plenty stiff, if there is any flex it is certainly not enough to notice. It could possibly come into play if you were building a 13 lbs scaler, I am not sure, but if you were going that route I am sure the end user would opt for the steel frame anyway. At that point weight is obviously not an issue...
I am happy with the TSS frame and skid setup. The increased clearance is immediately obvious and should make a CMS setup trouble free. I have already installed the SSD CMS and can say that it all went on with no drama and perfect fitment. I am building a SCX from ground up, will probably start a thread tomorrow, but I am very happy with the TSS frame as my base.
USP45 is offline   Reply With Quote
Old 03-08-2016, 12:04 PM   #63
~THE SCALE SHOP~
Laser cut steel SCXHR chassis back in stock
STANG KILLA SS is offline   Reply With Quote
Old 03-08-2016, 01:02 PM   #64
Saweeeet!
Mr.Joshua is offline   Reply With Quote
Old 03-08-2016, 07:07 PM   #65
Still really want one... but can't this week.
2JSC is offline   Reply With Quote
Old 04-04-2016, 03:25 PM   #66
~THE SCALE SHOP~
Customer Pic:
Thanks Eddie!
Old 04-07-2016, 11:13 PM   #67
What are those body post mounts from thanks
jmontes_21 is offline   Reply With Quote
Old 04-08-2016, 12:26 AM   #68
I was wondering that myself. Which body mounts work and do they end up in the same spot as the stock holes?
Old 04-08-2016, 02:15 PM   #69
Finally got to really put this chassis thru the paces. The raised upper links really helped in the climbing dept. If I could keep the front end down, it would climb it. Impressed to say the least. I'm really liking the chassis. Thanks!
Eric
Hotrodvw is offline   Reply With Quote
Old 06-07-2016, 04:40 PM   #70
~THE SCALE SHOP~
Customer pics, Thanks Travis
Originally Posted by travis c. View Post
Been running a TSS chassis on my 2.2 rig for a while now and have to say that I am very pleased with the performance and clearances over the stock chassis. I did remove the rear shock towers and replaced them with plastic Axial ones. The camera on my phone isn't the greatest, sorry for the lack of clarity, but here's some pics.............................
I put a bit of a bevel on the lower edge to aid in not getting hung up on obstacles like a sharp edge would.
Old 06-13-2016, 02:58 PM   #71
~THE SCALE SHOP~
Customer Pic, thanks Steven!
Old 06-13-2016, 05:04 PM   #72
~THE SCALE SHOP~
another customer pic, Thanks Kelly
Old 07-22-2016, 12:41 PM   #73
~THE SCALE SHOP~
Customer Pics:
Thanks Bruce
Old 07-22-2016, 01:45 PM   #74
~THE SCALE SHOP~
Customer pics
Originally Posted by Honcho907 View Post
love this chassis
Sent from my SAMSUNG-SM-G891A using Tapatalk
Old 07-22-2016, 03:48 PM   #75
Thanks for sharing my build Cory! Ill post more pictures soon!
heretobea is offline   Reply With Quote
Old 07-24-2016, 05:49 PM   #76
And Done!!..ish!.. a little more tuning would should get it solid
Honcho907 is offline   Reply With Quote
Old 07-25-2016, 08:37 PM   #77
Need to get this for my ground up build!
Ltd.yfz is offline   Reply With Quote
Old 08-11-2016, 06:13 PM   #78
Mine will be here Saturday
Old 11-30-2016, 10:11 AM   #79
~THE SCALE SHOP~
New!
Version 4! SCX10 II Compatible!
TSS SCXHR Chassis
The Scale Shop is very proud to release our all new SCX High Clearance chassis. This chassis fixes all the issues with the aging SCX10 chassis. Version 4 now fits BOTH the SCX10 AND the SCX10 II !
SCX10 dimensions and all factory mount points precisely replicated
Uses your existing skid, braces, and hardware
Front and rear "arches" raised 1/2"
More suspension up travel and full compression at any ride height
More clearance for CMS and panhard rods
Eliminates axles and upper links hitting chassis rails
Integrated shock towers
Dual raised upper link mounts, one positive and one negative anti-squat setup
More shock mounting options
Dual Bumper mounting positions, stock and raised 1/2"
Twice the torsional rigidity of stock frame
Comes in raw 12 gauge steel or 8 gauge aluminum ready for paint or welding
Combine with our TSS Smooth Skid for the Ultimate Performance Package! (OG SCX10 only)
Made in the USA
Version 4 now adds:
SCX10 II Compatibility
Laser Cut
SCX10 II Transmission mount holes
Adjustable Height Skid mount holes
More shock mount holes including both SCX10 1 & 2 stock locations
This picture really explains it all(Old V2 shown)
Combine with our TSS Smooth Skid for the Ultimate Performance Chassis for your SCX10 or Custom Build. (OG SCX10 only)
TSS SCXHR Chassis Rails
Available Here:
Chassis -
Old 11-30-2016, 02:18 PM   #80
I bought this chassis in the steel and love the clearences and the bumper locations, but it always bends side to side. Is there any thing to help prevent this? Thanks all
Evan Harich is offline   Reply With Quote
~TSS~ SCXHR Chassis Build & Info: Performance Chassis Upgrade - Similar Threads
~TSS~ SCXHR Chassis! The next evolution of SCX10 Performance Chassis STANG KILLA SS Chassis and Suspension 212 04-15-2021 03:05 PM
Gelande chassis issues & upgrade options DRW-FJ40 1.9 Scale Rigs 21 08-21-2015 11:07 PM
