07-28-2014, 02:30 PM | #1 |
Quarry Creeper Join Date: Jun 2014 Location: Grand Haven, MI
| Torquemaster Expert 35T 3S Gearing
Hey guys. I'm trying to get my rig done to take on my family vacation VERY soon. I don't have a ton of time to play with gearing before I leave. What would be a good starting point for gearing in my G6 with the Torquemaster Expert 35T on 3S? I have the stock 87T spur. My rig is a bit heavy, with the added wraith interior, steel beadlocks, metal bumpers, metal rock rails, and MIP driveshafts. Need something more for all-around rather than a crawl master. Where should I start? 14T on the pinion? Thanks! |
07-28-2014, 04:08 PM | #2 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
| Re: Torquemaster Expert 35T 3S Gearing
I'd say start with a 16t pinion and you could always move down to a 15t if that doesn't work out. Most of my rigs use 16t pinions besides my short course and erevo lol. As long as your temps aren't to hot and the torque is where you want it, you should be fine with a higher pinion like a 16t.
07-28-2014, 06:09 PM | #3 |
Starting out I would use a 14t pinion. If temps are good and you want a little more speed you can go bigger pinion after that.
07-29-2014, 12:08 AM | #4 |
4.6" Treps ? I'd start with the suggested 16t - 14t possibly going lower with those ^ tires what speeds are you wanting to roll with ? crawling or bashing ? check your motor temps for excessive heat... if it doesn't run hot... yer golden. |
07-29-2014, 07:00 AM | #5 |
Running the stock Trepadors that come in the kit, yes. I will start around 15T on the pinion and pack my temp gun with me. Thanks guys! |
Torquemaster Expert 35T 3S Gearing - Similar Threads | ||||
27 turn TorqueMaster Expert 540 | Norton | Electronics | 15 | 11-28-2013 06:02 AM |
HH Torquemaster Expert 35t hanging up. | Red04Cobra | Electronics | 9 | 10-02-2013 07:25 AM |
Torquemaster expert 13t vs crawlmaster pro 13 vs torquemaster pro 27t | cooperDG123 | Electronics | 6 | 05-08-2013 12:30 PM |
TorqueMaster Expert 540 | ickabob | Axial Wraith | 0 | 11-26-2011 09:38 PM |
