07-29-2014, 09:30 AM | #1 |
Quarry Creeper Join Date: Jun 2014 Location: Grand Haven, MI
| Single Spring on Icon Shock
Hey guys. I don't like how high the suspension sits at stock with my G6. I have backed the preload collars off as far as they will go, but I feel there is still too much spring holding the truck up. I was wondering if anyone has any ideas as to what single spring I could use. I want more sag in the suspension. Thanks for the help. I did a search and did not find the answers I wanted. EDIT - Should I just start with a super soft spring for the bottoms? http://www.amain.com/product_info.ph...Super-Soft-Red Last edited by 1967Typhoon; 07-29-2014 at 09:37 AM. |
07-29-2014, 10:17 AM | #2 | |
| Re: Single Spring on Icon Shock Quote:
Dudley Deadbolt's Adventure Thread by T-money | |
07-29-2014, 11:12 AM | #3 | |
Rock Stacker Join Date: Sep 2013 Location: Orlando
07-29-2014, 11:20 AM | #4 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
Typically, the first spring on a dual spring coilover (whether it is scale shocks or 1:1) is going to be softer so that it can absorb bumps easier and not have high enough spring rate to bounce you off an obstacle. As you get closer to the end of the shock cycle, The bottom spring should have a more firm spring rate to slow down the shock stroke to keep you from bottoming out on your shocks. It is definitely worth getting a softer, but still firm, lower set of springs and then get a good assortment of first spring springs. Unless your rig is going to be super heavy, you can probably get away with just tuning the first springs. |
07-29-2014, 11:28 AM | #5 | |
07-29-2014, 11:56 AM | #6 |
From what I understand the shorter (upper) springs already come in super soft from the kit, correct? Then the longer spring (lower) is more of a medium rate? I might try going with a soft rather than a super soft in the lowers if that is the case. |
07-29-2014, 03:32 PM | #7 | |
It may be worth changing the shock oil too to help match the sfter springs that you may be buying. You don't want the body/frame to flop around while sidehilling or at a strange obstacle. It's all about how you drive and what you want it to act like- shock oil and springs are cheap, go crazy. | |
Single Spring on Icon Shock - Similar Threads | ||||
King shock single spring conversion? | ProjectSCX10 | General Crawlers | 4 | 05-28-2014 10:03 PM |
ICON Shock builders question | Sactown_Summit | Axial SCX-10 | 8 | 05-19-2014 04:25 PM |
I need a single aluminum hr shock? | LavaCapCrawling | Losi Micro-Rock Crawler | 1 | 03-07-2013 08:08 AM |
Single shock IFS | GeoffSFAs10 | Traxxas Crawlers | 3 | 12-29-2004 07:18 AM |
