07-29-2014, 02:24 PM | #1 |
Newbie Join Date: Nov 2013 Location: canada
| front wheels surging at low throttle
When I hold my scx in air and run throttle at very low speeds the back wheels turn super slow and the front wheels kinda surge like almost pulse they stop then jump ahead then stop then jump ahead I hope this makes sense I made sure the notches on drive shafts lined up anything else I could try? Should I open up the front differential and take a look maybe I screwed up when I originally assembled it
07-29-2014, 02:47 PM | #2 |
| Re: front wheels surging at low throttle
Compress the front suspension and try it again. Odds are the driveline is near its max operating angle.
07-29-2014, 03:05 PM | #3 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
Are you running different driveshafts or longer shocks? The best way to make that stop is clocking the axle forward with a spacer in the links just a little bit (that's only if you're using aluminum links). Now say if you have aftermarket shocks then anything over..100mm can cause the driveline to bind a little bit. (Yes I've had it happen to me until I bought a droop kit). On my scx10 jeep I have 120mm shocks and even on a droop kit it made everything bind so I got a long threaded grub screw and put a spacer in the upper links..this stopped the binding and made the driveshafts turn at a much better angle (however I hate the ride height with those shocks and will be changing them out very soon).
07-29-2014, 03:24 PM | #4 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
| Re: front wheels surging at low throttle |
07-29-2014, 03:48 PM | #5 |
okay i just tried messin with it and when i compress the socks it makes no differance still surges when i go full throttle the differential makes slopping around sound so i think im gonna have to open it up and take a look if somthings wrong
07-29-2014, 06:30 PM | #6 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
Possible play in the locker.
07-30-2014, 06:55 AM | #7 |
Pebble Pounder Join Date: Feb 2014 Location: NH
For the driveshaft's, there's actually 4 points that need to match, not just the two notches on the shaft. The other two points are the pins in the couplers. Both the couplers and the notches should all be aligned with each other. |
07-30-2014, 07:21 AM | #8 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
| Re: front wheels surging at low throttle Sounds like your gear mesh is incorrect, make sure your pinion bearings are pressed all the way into the housing. If they are not, it will make the ring and pinion mesh to tight which will be noisy and notchy when running it.
07-30-2014, 09:47 AM | #9 |
hdmm are you talking about inside the dif ?
07-30-2014, 12:28 PM | #10 |
Newbie Join Date: Dec 2013 Location: 909
Driveshaft phasing. Make sure the pins in the joint are lined up the same as well as the notches on the shafts Axial SCX10 Dingo Axle Chatter & Fix: http://youtu.be/acrSdzzniiw Last edited by THX_138; 04-14-2015 at 08:27 PM. |
07-30-2014, 12:45 PM | #11 |
Rock Stacker Join Date: Mar 2014 Location: HK
The same topic is being discussed every week
front wheels surging at low throttle - Similar Threads | ||||
Sidewinder v3 surging throttle | B94Cast | Electronics | 22 | 03-23-2014 09:39 AM |
3s low throttle vs. 2s | Nicolasmj | Electronics | 10 | 08-27-2013 04:12 PM |
pics of FRONT LOW LOW wanted | dhoffroad | General Crawlers | 16 | 02-21-2006 08:10 PM |
surging/front axle not engaging | Jeepman97tj | General Crawlers | 1 | 01-02-2006 02:03 PM |
Surging when in low range/ axles won't shift | theone13 | General Crawlers | 3 | 09-02-2005 09:34 PM |
